air filter - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 07-27-2015, 06:01 AM Thread Starter
Default air filter
Does K&N make a air filter for victory motorcycles? If so are they worth buying?
mitchmartin14 is offline
post #2 of 18 (permalink) Old 07-27-2015, 06:39 AM
dtmmil's Avatar
lloydz does, its the only filter worth buying for it, but if you have other things done it may throw you into needing a tuner.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 18 (permalink) Old 07-27-2015, 07:32 AM Thread Starter
Default air filter
the only mechanical thing I have done is the exhaust
post #4 of 18 (permalink) Old 07-27-2015, 07:33 AM
dtmmil's Avatar
what did you do? slipons?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 18 (permalink) Old 07-27-2015, 07:50 AM
unbidden's Avatar
A much cheaper alternative to the Lloyds filter is the Vic high flow and remove the rubber strip on the filter box. Note that if you opt for the Tri Ovals, it comes with the filter and map.
unbidden is offline
post #6 of 18 (permalink) Old 07-27-2015, 08:09 AM
dtmmil's Avatar
yes but like i said, lloydz is the only filter worth buying
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 18 (permalink) Old 07-27-2015, 08:32 AM
Travis P's Avatar
+1 on what Drew is saying. Lloydz is the only filter worth buying.
Travis P is offline
post #8 of 18 (permalink) Old 07-27-2015, 08:38 AM Thread Starter
Default pipes
I sent the factory pipes to a man in Florida and he redid them to have sound.
post #9 of 18 (permalink) Old 07-27-2015, 02:42 PM
dtmmil's Avatar
gotcha, should be ok
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 18 (permalink) Old 07-27-2015, 02:43 PM
dtmmil's Avatar
unplug the O2 sensors also
currently bikeless
Hawley MN(sold)
dtmmil is offline
