Bag and trunk liner? - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-29-2015, 02:59 PM Thread Starter
Bigmike17's Avatar
Default Bag and trunk liner?
Has anyone lined the inside of their bags or trunk with a felt like liner? If so what would you do different? What adhesive did you use and material? Just curious and looking for ideas.
2014 Cross Country Tour
Freedom Performance exhaust, Lloydz VFC and a Lloydz Intake/filter, Lloydz ATS.
Bigmike17 is offline
post #2 of 13 (permalink) Old 07-29-2015, 03:20 PM
austxdan's Avatar
Have you tried that "Search" feature at the top of the screen? I'll bet you get some hits on that one.
Cheers,
D.
2014 Victory Cross Country - Suede Silver and Flames
Cee Bailey's 11" Dark Smoke windscreen
Miller Mufflers - Short Baffles
Lloydz ATS Timing Gear (+4)
Avon Grips w/Lloydz 1/4 turn Throttle Ring
RICZ Lay down license bracket
Sabertooth LED Saddlebag lights
"Goody's Custom" fork mounted lowers
Austin, TX
"In the beginning God created man, but seeing him so feeble, He gave him the dog." ---Toussenel
austxdan is offline
post #3 of 13 (permalink) Old 07-29-2015, 03:50 PM
wspollack's Avatar
I'm not that impressed with the built-in search functions on forums, even if some Google applet is being used. Instead, I use regular ol' Google, outside of the forum.
That is, you can tell Google -- www.google.com -- to look at only a given domain, and then do its thing. To do this, you just start the search box with site:, then enter the domain (and you can omit the www part), and then enter the search terms.
For instance, to search this site for, say, saddlebag liners, I brought up a regular www.google.com page, and in its search box I entered the following:
site:victoryforums.com saddlebag liners
The results I got back are much better than the results I got back when entering saddlebag liners in the drop-down search box on this forum page. Try it both ways, and see what you think.
Cheers,
Bill P.
wspollack is offline
post #4 of 13 (permalink) Old 07-29-2015, 04:10 PM Thread Starter
Bigmike17's Avatar
I did try "search" but I didn't find what I was looking for.
post #5 of 13 (permalink) Old 07-29-2015, 04:13 PM
dtmmil's Avatar
i never did install it but i bought some. trunk liner material at a local surplus hardware store, its a felt type material, but it by the yard, i was going to use spray in contact cement
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #6 of 13 (permalink) Old 07-29-2015, 04:15 PM Thread Starter
Bigmike17's Avatar
About the only thing I'm finding is the witch doctors kit. I was looking for something a little more do it yourself, with the look of the Witchdoctors kit.
post #7 of 13 (permalink) Old 07-29-2015, 04:29 PM
wspollack's Avatar
Okay, here's a thread (from 10/2013), with links to liner products from several vendors:
https://www.victoryforums.com/showthread.php?t=50569
See if the stuff in that thread helps.
Cheers,
Bill P.
post #8 of 13 (permalink) Old 07-29-2015, 06:08 PM
dtmmil's Avatar
not following? not much more do it yourself then a roll of material and can of glue? are you trying to make removeable?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 13 (permalink) Old 07-30-2015, 09:24 AM Thread Starter
Bigmike17's Avatar
Nah I wasn't trying to make it removable just curious about the difficulty of installation and what materials might be better etc if I was to attempt to do it without a pre-cut set.
wspollack- Thank you! I found the saddlebag liner kit video buried on you tube last night. Thanks gentlemen!
post #10 of 13 (permalink) Old 07-30-2015, 11:47 AM
I got the same one witch doctors sells. It was easy to install. Pieces are pre cut to fit. It includes adhesive.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
