Need help...quick..died...fuel starved - Victory Forums - Victory Motorcycle Forum
post #1 of 28 (permalink) Old 08-01-2015, 07:08 PM Thread Starter
Default Need help...quick..died...fuel starved
Hey guys
Slammed on brakes at stoplight and bike died. Wont restart. Like starving for fuel. Need advice. Checked fuse...its ok.
Plz help
kllrbee is offline
post #2 of 28 (permalink) Old 08-01-2015, 07:12 PM Thread Starter
Fuel pump wont kick on when turn key on
kllrbee is offline
post #3 of 28 (permalink) Old 08-01-2015, 07:17 PM
what year and model
is the battery cables tight. 10mm wrench
think the fuel pump runs off relay not a fuse.
Is bike in neutral
you really aren't telling us much
post #4 of 28 (permalink) Old 08-01-2015, 07:20 PM Thread Starter
2014 XC...battery cables tight....i saw the relay...how do I check if bad relay tho?
kllrbee is offline
post #5 of 28 (permalink) Old 08-01-2015, 07:20 PM Thread Starter
Bike is in nutral...
kllrbee is offline
post #6 of 28 (permalink) Old 08-02-2015, 07:14 AM
Amboymike's Avatar
maybe the "tip over sensor" jarred loose????
_____________________________________
2012 Crossroads
Amboymike is offline
post #7 of 28 (permalink) Old 08-02-2015, 07:38 AM
Motorbikerx's Avatar
Kill switch on?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 28 (permalink) Old 08-02-2015, 04:37 PM
WABlue's Avatar
Default Volt meter
You could try a test light but a volt meter will be better on each post.
2013 Cross Country Tour
Lloyds Air Cleaner
Lloyds Timing Wheel
Thrush exhaust Mod
O2 sensors disconnected
1/4 turn throttle ring
195/55/16 rear tyre
WABlue is offline
post #9 of 28 (permalink) Old 08-02-2015, 04:54 PM Thread Starter
So I ended up getting a tow home last nite. As I was waiting, i had the bike hazards on so battery died. I took off cables and fully charged it hoping that maybe it would teset the tilt sensor (if that was the problem). No good....bike still acts like starving for fuel.
Only mods ive done is lloyds air filter and atom bombs.
I took out a plug thinking that maybe I choked it when I stopped suddenly. Plugs not fouled or wet....actually looks slightly lean...but not bad....looks like it should.
Im thinkin its the pump....whats the "easiest" way to go about testing it on this bike?
I already have the seat and wedges off....and tank is unbolted by the seat so most lines should be accessible.
Also...just throwing this out there if it comes to it. I am still under warranty....ive had for just over a year, but my dealer gave me a 2nd year with $50 deductible. Not sure if this was somethin my dealer does or if they all do....but thought I would mention it. Funny thing is that Ive never owned any car or bike that I had a warranty on....Dont even know how to use it....haha.
I assume i just call the dealer....but do I still have to pay for a tow there? Sorry if that seems like a dumbass question....but like I said....never had a warranty.
Never had to have a vehicle towed either....another first.
Lots of questions....help me out here....thnx guys.
kllrbee is offline
post #10 of 28 (permalink) Old 08-02-2015, 04:56 PM
kodiakwood2's Avatar
This just happened to me, pulled in clutch, bike died, cranks over right, but no sound that the fuel rail is pressurized when you flip the kill switch. Turns out my fuel pump died. I hope the best for you.
Fortunately mine was covered under my extended warranty, $375 for the pump plus labor.
Let us know what happens
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
