Lloydz air cleaner oil or not oil - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 15 (permalink) Old 08-04-2015, 02:33 PM Thread Starter
vindex1963's Avatar
Default Lloydz air cleaner oil or not oil
I've read many posts about oiling and not oiling the Lloydz Hiflow air filter. Seems both are right. I emailed Lloydz and this was the response. I'm posting this with permission from Danny at Lloydz.
"Our filter is dyed. You can clean it with soap & water, rinse from the inside out, let air dry and you’re good to go. The filter needs to be cleaned about every 20K.
This only applies to the XC filters that we’ve sold in the last 2 years. The earlier ones were oiled and they could be cleaned and re-sprayed with the k&n filter kit."
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 15 (permalink) Old 08-04-2015, 06:20 PM
Tarzan's Avatar
I have the older one. I have to oil it.
'14 Ness XC
Tarzan is offline
post #3 of 15 (permalink) Old 08-04-2015, 07:26 PM
Ahoutzer's Avatar
I don't know which one I have, so I'll keep wondering.
2012 XCT (Blackbird)
Forged bars & JTD lowers
Stage 1 flash & Tri-ovals
LLoydz ATS @+6*, Air filter, Drop-in cams
VFCIII tuned by KevinX
Madstad with 13-inch shield
Garmin Zumo660
Tri-city Performance floorboard footrests
Heel shifter
Corbin saddle & backrest
Cee Bailey's bag liners
Wolo Badboy horn
KuryAkyn Sabertooth lights
Ahoutzer is offline
post #4 of 15 (permalink) Old 08-04-2015, 07:28 PM Thread Starter
vindex1963's Avatar
You don't know? Didn't you install it or ever service it?
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 15 (permalink) Old 08-04-2015, 07:31 PM
Ahoutzer's Avatar
I installed it, but how would I know which model it is? Confession: it is way overdue for servicing. I don't remember exactly how long ago I bought and installed it, but TOO long. I just don't like removing the gas tank.
Garmin Zumo660
Heel shifter
Wolo Badboy horn
Ahoutzer is offline
post #6 of 15 (permalink) Old 08-04-2015, 07:34 PM Thread Starter
vindex1963's Avatar
I hear you!! I had a neighbor come over to carefully route the gas line out. I'm taking Danny's word and clean it at 20,000.
If the filter is dyed blue it's the new dry style.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #7 of 15 (permalink) Old 08-04-2015, 07:37 PM
Ahoutzer's Avatar
Blue? I didn't see that in your original post. That gives me a possible way to determine which kind it is.
Garmin Zumo660
Heel shifter
Wolo Badboy horn
Ahoutzer is offline
post #8 of 15 (permalink) Old 08-04-2015, 07:44 PM Thread Starter
vindex1963's Avatar
Just like this.
http://www.lloydz.com/store/item_vie...itemid=1000130
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #9 of 15 (permalink) Old 08-04-2015, 11:12 PM
A short call to Lloydz will remove all doubt. Been here, done that.
post #10 of 15 (permalink) Old 08-05-2015, 03:02 AM
Motorbikerx's Avatar
With my TorqueTubes I clean an re-oil
When I contacted K&N requesting service interval they said up to 50,000 miles!
And qualified it by saying when you cant see the mesh on the filters anymore its time to clean.
Admittetly my filters are a damn sight easier to R+R than a Cross bike.
The filter medium may or may not be the same though as theyre the clean and oil they are probably same as the clean and oil type on Cross bikes.
Theres been a theory on here that the KNs filter better with some dirt buildup as theyre almost transparent when held up to the light.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
