Klock works windscreen crack - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 10-18-2012, 08:11 PM Thread Starter
Default Klock works windscreen crack
I've had a Klock works shield on my XCT for about 400 miles and today I found a crack at the left lower mount. I've put shields on before and I know I did not over tighten this thing. It is brand new and broken. I did get nailed by some crazy cross winds today, I do know it was not there before today as I just got done doing a full detail on the bike and polished out the screen. Calling the dealership tomorrow, better be able to warranty the thing.
Anyone else had this happen or have heard of issues with Klock-works?
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #2 of 5 (permalink) Old 10-18-2012, 08:19 PM
NOEMTZ's Avatar
Saw one today cracked on the flared part. No obvious reason for it...just cracked.
www.noemtz.com
NOEMTZ is offline
post #3 of 5 (permalink) Old 10-18-2012, 08:29 PM
wspollack's Avatar
Yeah, it's been a problem. Here's a couple of threads to get you started:
https://www.victoryforums.com/showthread.php?t=10433
https://www.victoryforums.com/showthread.php?t=13491
Cheers,
Bill P.
wspollack is offline
post #4 of 5 (permalink) Old 10-19-2012, 07:12 AM Thread Starter
Thanks for the links, must have failed at searching last night. Spelling the brand right would have helped.
Mine must be the new version as I got a ton of washers with it. I think I'll add a foam washer as well on the new one.
ChuglyXJ is offline
post #5 of 5 (permalink) Old 10-19-2012, 01:13 PM
Rajder's Avatar
I had one of the first Klock Werks windshields and it cracked at the mounting holes. They did replace the windshield and told me to add rubber washers to the top of the bolts along with the bottom of the bolts. That worked for a few thousand miles. But unfortunately I've got cracks around the mounting holes again.
I really like the windshield but I may have to go another direction in the future. This is the 3rd windshield that I've had to deal with cracking along the mounting holes (1 Victory flip and 2 Klock Werks) and it's getting pretty old.
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
