Possible to charge battery through power outlet? - Victory Forums - Victory Motorcycle Forum
post #1 of 36 (permalink) Old 10-23-2012, 05:11 PM Thread Starter
Default Possible to charge battery through power outlet?
Just as the title states, is it possible to charge the battery (or keep it tended) through power outlet? I have the CCT which has cigarette-style outlets on handlebar (fairing?) and inside left, hard lower storage compartment.
Thnx!
2012 CCT, White
Grimloktt is offline
post #2 of 36 (permalink) Old 10-23-2012, 05:31 PM
I would think so as long as there is power there when key is off it would feed the battery.
But your lighter is controlled by the key I bet.
post #3 of 36 (permalink) Old 10-23-2012, 05:56 PM
Mrchips's Avatar
I have a 12 CCT and the outlet on the fairing and the one in the trunk fro certain work when the key is off.
Command Master Chief, USCG (NOW RETIRED)
Iola, TX
Mrchips is offline
post #4 of 36 (permalink) Old 10-23-2012, 06:31 PM Thread Starter
Thnx. I went out and plugged in my cigarette-lighter outlet powered air pump and tried the flash light accessory--with the moto key off. It powered the light. So, I guess I'll give charging this route a go.
2012 CCT, White
post #5 of 36 (permalink) Old 10-23-2012, 06:55 PM
RonBou's Avatar
I bought an adapter from Battery Tender and have used it to charge the battery through the power outlet on the fairing. Works fine.
Ron
2012 Victory Cross Country Tour (Stage 1)
2011 Victory Cross Country (traded in on XCT)
2009 Triumph Rocket III Touring (traded in on XC)
1998 Valkyrie Tourer (Hydralocked - sold as is)
1966 Honda 305 Dream (for sale)
1967 Honda 305 Scrambler (project)
1982 Honda CB900 Custom (need to put back together)
RonBou is offline
post #6 of 36 (permalink) Old 10-23-2012, 08:17 PM
steviej's Avatar
Powerlet.com makes a cable that will connect a Battery Tender, Yuasa or similar trickle charger with a SAE cable to the cigarette outlet and allow charging ($13.95).
Click here
I have used Powerlet many times and like their products. The even made me a custom cable of 12" long to connect my Garmin GPS to the cigarette lighter. This way I didn't have have 3' of Garmin cable wire tied to my handlebars.
steviej
steviej is offline
post #7 of 36 (permalink) Old 10-23-2012, 09:16 PM Thread Starter
Thnx, all. I just went with this: http://www.walmart.com/ip/Battery-Te...apter/15779495
2012 CCT, White
post #8 of 36 (permalink) Old 10-23-2012, 09:44 PM
Thnx!
I think your XCT should have come with a battery tender wire in the front of your bike.
orbiker is offline
post #9 of 36 (permalink) Old 10-24-2012, 05:51 AM Thread Starter
I took a look and didn't see one. Searching the internet, some had said Victory stopped installing them starting with '11 year group.
2012 CCT, White
post #10 of 36 (permalink) Old 10-24-2012, 06:02 AM
TNXR's Avatar
My 11 XR did not have a battery tender wire hooked to it either. Piced up one that would work with my tender at local auto parts store for 3 bucks.
2011 Cross Roads Sunset Red
TNXR is offline
