To cam or not to cam - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 19 (permalink) Old 08-20-2015, 08:56 PM Thread Starter
Default To cam or not to cam
HI All, So far I have done a set of D&Ds and unplugged the O2s. I have the fuel processor, cam gear, and Lloyds air filter sitting in a box (yup, been that busy this year to put them in). I was also waiting to put the parts in so I could get it Dynoed with Kyle.
Well, After doing a couple nice tours this summer (about 8k miles worth) I discovered that I can run out of power riding 2 up doing a long uphill pass. I think the cams might help me out here but I was curious about mileage. RIght now without beating on the bike i get about 43-45 mpg.
What are you guys getting for MPG with cams?
wingnut is offline
post #2 of 19 (permalink) Old 08-20-2015, 09:09 PM
dtmmil's Avatar
a good tune with cams you will get the same mpg. what rpms do you ride at? do you wind it up often? my typical riding i dont get above 3,000 rpms much, so after i added cams i wasnt impressed. they really wake up at around that 3,000 mark and up.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 19 (permalink) Old 08-20-2015, 09:17 PM Thread Starter
My typical riding doesnt go above 3000 also. But it does when doing serious hills, hooligan riding and passing.
wingnut is offline
post #4 of 19 (permalink) Old 08-20-2015, 09:21 PM
dtmmil's Avatar
i would talk it over then with kyle to see what he recommends, but getting all your parts on and a good tune will be night and day to what you have now
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 19 (permalink) Old 08-20-2015, 09:23 PM
Seriously, you're questioning if you need cams or not. I'll be glad to help you here friend. YES, get the Lloyds cams!
Lloyds DR cams, Lloyds air filter, Lloyds timing wheel (+4), Lloyds 1/4 turn throttle ring, PCV, Tri Ovals, dyno tune by Rylan Vos = +30 hp, +20 ft.lbs/torque, +3mpg, -50% felt engine heat.
Clear enough?
63625 likes this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #6 of 19 (permalink) Old 08-20-2015, 09:46 PM
newj64's Avatar
Based on your riding style (around 3000 rpm) Talk to Kyle about his torque cams. They make 100ft-lb at 2300rpm and outperform Lloydz DR cams up to 4000rpm
14' Cross Country
~PCV, Timing Wheel +6, Thrush Mod Exhaust, Madstad 11" windshield
newj64 is offline
post #7 of 19 (permalink) Old 08-21-2015, 12:47 PM
wingnut
you should say what year and model you have. Add it to you signature like we all have
post #8 of 19 (permalink) Old 08-21-2015, 01:47 PM Thread Starter
Whoops, I usually have info posted but I guess I missed it here. '14 cct
wingnut is offline
post #9 of 19 (permalink) Old 08-21-2015, 06:24 PM
Motorbikerx's Avatar
Cams really start honking above 4000
Yeah they do start to perform over 3000
Under 3000 my 100 cube with stock cams and torquetubes, pipes, and 4 deg. advance has a good solid 100 ft lb rising to 108 ft lb
What revs are you actually pulling when youre overtaking?
Are you willing to sacrifice grunt in the 2-3 range for 4 and up performance?
Are you living in a state where hammering along at 80mph plus is okay (wish I was)
If so hotter cams are the go!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 19 (permalink) Old 08-21-2015, 07:53 PM
rewindguy's Avatar
Need I say more? KMC Torque Cams - I am averaging 52 MPG @ 70 MPH
2014 Cross Country Tour
Goldrush / Black
rewindguy is offline
