LED Lights - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 09-02-2015, 08:04 AM Thread Starter
Jamming's Avatar
Default LED Lights
So I ordered a set of these Cree LED Lights I knew I was rolling the dice but it worked out. Decent price and they are pretty bright.
I used a switch that fit in the space on the XC dash, but I don't like it so I ordered both the heated grip and driving switch from Victory. I figured if I have to disassemble the dash again I'm only gonna it one more time. What a PITA !
I also installed a powerblock inside the fairing. Note: I have not tied it all up in this photo.
Now my horn and lights have fuses and the circuits are on the block which is fused and I can still add 4 more fused circuits.
I decided to mount the lights off the lower mount for the chin fairing using longer bolts and a spacer. I fabbed up the brackets and squirted some paint on them. If they work and I like them, I'll fab up the final brackets. I tend to prototype on the fly.
So far so good, I got them aimed last night and the lights are more of a flood not a spot but they do light it up well. I didn't take pics last night...sorry...I think they work really well for daytime driving lights/making me more conspicuous at night.
I think I'll find some small round LED driving spots and mount them up next to or under/top of these. My goal is to look like a UFO out there. Seriously...I want people to go WTF is that that?
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #2 of 11 (permalink) Old 09-02-2015, 08:16 AM
doobliss's Avatar
Looks clean to me! And the attention grabbing will make people aware of you. Hopefully it won't be like a bug toward light though.
doobliss is online now
post #3 of 11 (permalink) Old 09-02-2015, 08:49 AM
A question I have installed LED lights on my XCT and I have problems with the FM interference and my Radio (FM signal) is useless. Do you have any problems with the lights that you have installed?
2014 XCT, Utopia Backrest, Guard Dawg, Longhorn brake pedal, ISO Longhorn shifter, Arlen Ness gas cap, VM-1 Cams, Lloydz ATS, Lloydz air filter, PCV, Madstad Windshield, Victory HID, Vance & Hines Hi-output. 118/120 Dyno tuned by Kyle.
Jlvazquez6 is offline
post #4 of 11 (permalink) Old 09-02-2015, 09:38 AM Thread Starter
Jamming's Avatar
I don't know. I rarely turn on the radio. I'll check and let you know.
Jamming is offline
post #5 of 11 (permalink) Old 09-02-2015, 09:53 AM
Looks like the same lights I have. I mounted them on the crash bar for a wider 'light triangle'.
https://www.victoryforums.com/34-vict...ng-lights.html
post #6 of 11 (permalink) Old 09-02-2015, 10:41 AM
necoachbw's Avatar
I had the same problem and I added ferrite beads to each light which I picked up at Radio Shack for about $3 and they just snap on, and the mechanic moved my antenna wire away from the light wires and that has improve reception greatly. I am able to pick up the station farther away then before.
Nebraska
2014 Tequila Gold Cross Country
necoachbw is offline
post #7 of 11 (permalink) Old 09-02-2015, 10:50 AM Thread Starter
Jamming's Avatar
That's the same lights ! I almost mounted them to the bars, I have the clamps. I decided to go where I did...for now That may change depending how much light they shed on the road.
Jamming is offline
post #8 of 11 (permalink) Old 09-02-2015, 10:58 AM
I did the same, as the matter of fact beside the Ferrites, and some toroid rings, I also disconnected the lights from the AUX plug behind the faring and connected them straight to the battery, just to have the wires away from any antenna wires, and nothing, if they are on, no FM radio, as soon as they are disconnected FM radio comes alive again.
post #9 of 11 (permalink) Old 09-02-2015, 11:15 AM
Currentman's Avatar
Led circuitry creates pulse width modulation which can block FM. Purchase a ferrite choke with a range of 1Mhz-300Mhz and place it on the wiring of the led's as close to the light as possible, this should resolve your issue
2013 Cross Country Tour
1/4 turn throttle ring
VFC III - 3,3.5,1,0,3,2.5
Lloydz ATS +5
Freedom Performance true duals
Lloydz air filter
Currentman is offline
post #10 of 11 (permalink) Old 09-02-2015, 11:29 AM
I dig how you mounted yours.
