LED Headlight Problems - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 14 (permalink) Old 09-18-2015, 03:26 PM Thread Starter
Cmo1k's Avatar
Default LED Headlight Problems
I installed aftermarket LED bulbs (yes, not the Victory Headlight) and since then I have no radio reception! The radio works great in Park mode with the lights off. Even tried moving the antenna cable and it still has interference when I pull the headlight a couple feet out.
I read somewhere that these bulbs can actually put out RF interference. Sometimes a grounding issue. Anyone else have this problem?? Thanks.
Cmo1k is offline
post #2 of 14 (permalink) Old 09-18-2015, 04:02 PM
Which lights did you install?
Did they come with a small box like a ballast?
If so, where did you put them?
broggyr is online now
post #3 of 14 (permalink) Old 09-18-2015, 05:29 PM
Ahoutzer's Avatar
It is very common for LED lights to interfere with radio signal. You MAY get SOME relief by using ferrite chokes on the wires powering the lights, but this has never done a satisfactory job for me -- it just helps some. Ferrite chokes can be found at Radio Shack stores.
2012 XCT (Blackbird)
Forged bars & JTD lowers
Stage 1 flash & Tri-ovals
LLoydz ATS @+6*, Air filter, Drop-in cams
VFCIII tuned by KevinX
Madstad with 13-inch shield
Garmin Zumo660
Tri-city Performance floorboard footrests
Heel shifter
Corbin saddle & backrest
Cee Bailey's bag liners
Wolo Badboy horn
KuryAkyn Sabertooth lights
Ahoutzer is offline
post #4 of 14 (permalink) Old 09-18-2015, 05:39 PM
Travis P's Avatar
LED lights should not interfere with radio???? HID I have heard of but not LED. Maybe I learnt something new today?
Travis P is offline
post #5 of 14 (permalink) Old 09-18-2015, 07:10 PM
Ahoutzer's Avatar
LED lights DO interfere with radio. Look up 'Pulse Width Modulation'.
Garmin Zumo660
Heel shifter
Wolo Badboy horn
Ahoutzer is offline
post #6 of 14 (permalink) Old 09-18-2015, 07:53 PM
dentdave's Avatar
I have Led driving lights from Big bike Parts on my bike and they interfere with my fm radio and anybody else next to me at a light. I called them about it and they have no clue what to do. I do listen to XM threw my gamin 665 with no issues.
Being that we don't use the FM radio I've never looked into a fix, good luck finding a solution and share it with us if you do.
David
www.dentdave.com
2012 Cross Country Tour
IBA # 33520 - 1040 in 24, 04 / 2008
1036 in 24, 10 / 2014
Michelin Primacy Alpin PA3 ZP 195/55/16
dentdave is offline
post #7 of 14 (permalink) Old 09-18-2015, 08:21 PM
Travis P's Avatar
Good to know... I always like to learn new things.
Travis P is offline
post #8 of 14 (permalink) Old 09-18-2015, 08:40 PM
SubDude's Avatar
What the heck is park mode?
Bryan P. Johns - Southeast Michigan
2016 Indian Chieftain - Silver Smoke
SubDude is offline
post #9 of 14 (permalink) Old 09-19-2015, 07:01 AM
Scotchbriar's Avatar
On my XC I can push in and turn the key to put it into this mode. The headlight will not be on, but the flashers, multi-fuction display, tail lights, radio, etc will all work. You are also able to remove the key in this mode. If you needed to leave your bike on the side of the road with the flashers going you could put it in this mode.
id-man likes this.
2013 Victory Cross Country
Victory Motorcycle Club Treasurer
River Cities Victory Riders (RCVR)
Secretary/Treasurer
www.rcvrclub.com
Scotchbriar is offline
post #10 of 14 (permalink) Old 09-19-2015, 08:38 AM
SubDude's Avatar
Wow, I should probably read my owners manual huh!
Scotchbriar likes this.
SubDude is offline
