HID and my radio - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 26 (permalink) Old 09-20-2015, 04:31 PM Thread Starter
vindex1963's Avatar
Default HID and my radio
I added the HID to my 2015 Cross Country right away and in the two months I've owned it I just thought the radio reception sucks. Yesterday I was telling someone how it doesn't scan for stations so we turned the key to AUX (no headlight) and it picked up a TON of stations static free. I turned on the headlight and yea terrible reception and it won't scan just static. I moved the ballast as far bottom right as it would go and it's exactly the same.
I know this issue is a beaten one and I see a LOT of fixes or attempts at fixing but has anyone found a real fix?
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 26 (permalink) Old 09-20-2015, 07:08 PM
dtmmil's Avatar
where did you get your kit? crossroads suggested spot is in the upper fairing mount, i know of a guy that mounted his on the outside of the fairing mount, and squatch here made some cage for his
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 26 (permalink) Old 09-20-2015, 07:14 PM
Travis P's Avatar
Mine was so bad it was causing interference with the left speaker as soon as I turned the key on. I moved it up to CR's suggested spot and it's better but not perfect.
Travis P is offline
post #4 of 26 (permalink) Old 09-20-2015, 07:15 PM Thread Starter
vindex1963's Avatar
I drilled a small hole in the aluminum fairing brace directly behind the light and screwed to it.
mine is a victoryhid
Even local channels fade in and out. I don't use the radio very much but when I do I want it to work.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 26 (permalink) Old 09-20-2015, 09:27 PM Thread Starter
vindex1963's Avatar
Inner upper fairing?
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #6 of 26 (permalink) Old 09-20-2015, 09:31 PM
dtmmil's Avatar
you can see here where i had mind mounted, had the two velcrod together, then velcrod to the fairing mount
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 26 (permalink) Old 09-20-2015, 09:41 PM Thread Starter
vindex1963's Avatar
Attachment 154610
Is that what I see in the bottom right of the picture? Some wrap foil around them.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #8 of 26 (permalink) Old 09-20-2015, 10:02 PM
dtmmil's Avatar
right here, i have the top one pulled off in the pic. you can see it in there though
vindex1963 likes this.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 26 (permalink) Old 09-21-2015, 12:02 PM
Jerry the video man has this video about adding a air horn.
But he also talks about add a diode. Now I don't know but maybe this will give you some help. So maybe get a hold of Paul and he can give you some help.
https://www.youtube.com/watch?v=BNK-...fpc_7rI6kt2kCx
post #10 of 26 (permalink) Old 09-21-2015, 12:47 PM
I'm waiting for some more feritte cores to come in to put on the power wire for the hid ballast. I have one on there now and it helped get a couple of stations back in
vcc14 is offline
