Windvest Windshield Advice - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 43 (permalink) Old 10-02-2015, 08:17 AM Thread Starter
wheelsm's Avatar
Default Windvest Windshield Advice
Looking for some advice here. I want to replace my stock windshield with a Windvest windshield. The question is size. I'm 5'11". According to their chart, an 11" windshield is recommended. That seems a little tall to me. Anyone out there of similar size to me have experience on what size you use and recommend? I don't mind a little wind in the hair, but I am wanting to deflect as much wind/rain around me (especially in colder riding months here in Minnesota).
If you prefer a different windshield than Windvest, I'm open to your recommendations there as well!
- Mark
2015 XCT, Red/Black, Windvest
wheelsm is offline
post #2 of 43 (permalink) Old 10-02-2015, 09:22 AM
LILMAGS500's Avatar
I'm 6'2" and am running the 9" but I have had the 11" , it may be too tall for you . I would recommend the 10" actually for your height . I like the shorter shield for the warmer temps , but now I wish I was running the 11 ...
LILMAGS500 is offline
post #3 of 43 (permalink) Old 10-02-2015, 10:18 AM
Depends on if you slouch. If so then, yes, the 11" may be a bit tall. If you tend to ride with good back posture you should be just fine with the 11". I'm 5'10" and do well will with a 13" but would be fine with an 11".
You can always trim an inch or two off but you can't add any.
post #4 of 43 (permalink) Old 10-02-2015, 01:50 PM Thread Starter
wheelsm's Avatar
Thanks LILMAGS500. One question: With the 11" and your height, I'm assuming you aren't looking through the windshield and your eyes are just over it. Is there a fair amount of "eye clearance" above the windshield using that size for you?
- Mark
wheelsm is offline
post #5 of 43 (permalink) Old 10-02-2015, 01:53 PM Thread Starter
wheelsm's Avatar
Thanks, Bbob. Similar question for you. With your 13" are you looking through the windshield or over it?
- Mark
wheelsm is offline
post #6 of 43 (permalink) Old 10-02-2015, 02:52 PM
LILMAGS500's Avatar
Welcome , you will look over it , you cant look through a WV its too dark . I can easily look over the 11" also ...
post #7 of 43 (permalink) Old 10-02-2015, 03:40 PM
I'm 6' and using the 11" Windvest I thought the bubble was just a little too low. I switched to a Gustafsson 12" Euroflip and its perfect.(I see fully over both)
At 5' 11" the 11" Windvest will probably be great for you
post #8 of 43 (permalink) Old 10-02-2015, 04:22 PM
kodiakwood2's Avatar
I'm 6'-1" using the 10" windvest. Kinda wish I had the 11" at 65mph there is a lot of wind banging around my head. Although that could be the empty space between my ears. I look well over the 10", you don't even notice it after a while
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #9 of 43 (permalink) Old 10-02-2015, 04:24 PM Thread Starter
wheelsm's Avatar
Thanks for the input, everyone. After reading these, I'm leaning toward the 11". Now I have to convince my wife this would be a great B-day gift!
- Mark
wheelsm is offline
post #10 of 43 (permalink) Old 10-02-2015, 06:10 PM
vindex1963's Avatar
I'm 6'3" and have the 11" and easily look over it.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
