Cross Roads Rear Tire issue - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 15 (permalink) Old 10-11-2015, 07:58 AM Thread Starter
Send a message via Skype™ to nealflora
Default Cross Roads Rear Tire issue
I have a 2012 Cross Roads (got new in 2013) that I have less then 3000 miles on. I noticed the rear tire was bald and had cord showing! After less then 3k miles? Obviously I took it to the shop and am getting a new tire BUT.... Why is the tire worn that much in such a short time with such low mileage?
Anyone else have this problem
"Keep the rubber side down"
Neal, Marco Island Florida-2012 Vegas, 2012 Cross Roads
nealflora is offline
post #2 of 15 (permalink) Old 10-11-2015, 08:23 AM
LILMAGS500's Avatar
I have 17,000 + on my stock tires and they still have a little more to go .... Something may be out of alignment on your bike .
LILMAGS500 is offline
post #3 of 15 (permalink) Old 10-11-2015, 08:55 AM
Low tire pressure and hard launches would contribute but that's still a pretty low number. I would have to agree that you have a tracking problem and the rear tire movement is not true. That far off I would think you'd be having some serious belt noise and wear as well.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #4 of 15 (permalink) Old 10-11-2015, 09:42 AM
and i thought mine was bad when i got only 8000 miles out of mine. i know i ride hard and get on the throittle when taking off. so any fast wear on my tires is a direct result of my driving. now my Hionda VTX is a lot better but then again it is a much light bike and I ride that miostly one up. im not a fan of Dunlap and maybe the next time i will put Commander II on.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #5 of 15 (permalink) Old 10-11-2015, 11:52 AM
wspollack's Avatar
1) What PSI do you set the tire at?
2) How often do you check it?
3) And when you do, you don't use one of those pencil gauges, or a gauge at a gas station pump, do you?
4) You check the pressure when the tire's cold, right?
IMHO, the pressure's been way too low, or you're a really big guy with a full-figured passenger, or you've been doing smoky burnouts, or some combination of those three. I get a full season -- typically 8,000 - 9,000 miles -- out of my back tires, and not anywhere near cord showing (but for convenience, get a new rear at the start of each season).
Cheers,
Bill P.
wspollack is offline
post #6 of 15 (permalink) Old 10-11-2015, 02:07 PM
Wood Welder's Avatar
Wood Welder is offline
post #7 of 15 (permalink) Old 10-11-2015, 07:16 PM
wspollack is spot on and you should answer his questions Neal. I am OCD about tire pressures and maintain 40 front and 42 rear. I endeavor to operate my bike smoothly. I am not slow, but I do everything fluidly - no hard accelerating or braking and smooth but deliberate steering inputs. As a result, I regularly get around 20K out of a rear tire. My record is 22,000+ on a Dunlop Elite. You can do that too.
vindex1963 likes this.
RICZ is online now
post #8 of 15 (permalink) Old 10-11-2015, 07:27 PM
vindex1963's Avatar
19,000 is my best on a big heavy Ultra Classic. Engine braking will kill a rear tire quick.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #9 of 15 (permalink) Old 10-11-2015, 07:32 PM
That 22K was on a 1983 Yamaha Venture mostly two up and long distance touring. Shoulda mentioned that before.
RICZ is online now
post #10 of 15 (permalink) Old 10-16-2015, 10:48 AM
johnnyplano's Avatar
If you're not a big guy with low tire pressure doing burnouts...
Do you by chance have a Victory driver backrest? This may be a long shot, though not unheard of:
Those things will push down through the mount, into the rear fender, possibly push through a little plastic access door on top of the fender and make contact with the tire while you're riding. (?) I'd think you'd notice some sound from that area or vibration in your back...just gotta pop off the seat and take a looksy.
2013 Cross Roads Classic
Tri-Oval Stage 1
Lloydz ATS
OEM Tachometer, Windshield Lowers, Driver & Passenger Backrests
Ultimate Midrider Seat
Kuryakyn Sabertooth Tail Lights
Ricz Lay Down License Plate Bracket
28,000 (s)miles and counting...
johnnyplano is offline
