It's not another oil thread - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 12 (permalink) Old 10-18-2015, 03:20 PM Thread Starter
Default It's not another oil thread
I'm not asking which oil is better for my engine. My 2011 xc has only 8000 miles on it. I've noticed the 2nd gear slipping out or sometimes it's hard to put in gear. I know this is an inherited problem with our transmissions. My question is would amsoil or other oil, be better for the transmission? Would it fix the problem? But still be good for the engine? I've only ever used victory oil. Thanks
Terry is offline
post #2 of 12 (permalink) Old 10-18-2015, 03:31 PM
Radar_usvmc's Avatar
When I got my bike, the PO said that it had Shell Rotella oil. At the next oil change, I used the Vic oil change kit. Then I started noticing it becoming harder to shift down out of 3rd into second. It is the only gear that does it. I also find that it passes neutral a LOT when trying to put it in neutral. I don't know what the best oil to use is, but it definitely acted better with the Shell in it.
~Radar~ USVMC
2012 Victory Cross Country
(Vance and Hines Hi output exhaust, Lloydz filter, Lloydz ATS, Lloydz VM-1 cams, PCV (Dyno tuned at 115HP/116TQ), 1/4 Turn Throttle Ring, LED headlight, LRS 11" windshield, WWC chrome fork guards, hydraulic clutch, Driver's backrest, keyess ignition and alarm, tourtech long arm highway pegs, Kuryakyn flame grips, Kuryakyn flame brake pedal)
Radar_usvmc is offline
post #3 of 12 (permalink) Old 10-18-2015, 06:51 PM
Motorbikerx's Avatar
My Vegas had the same problem when I bought it with 14,000 kms on it.
After advice from forum members in the know, I adjusted my shifter closer to my boot, as well as ensuring my clutch cable is always kept lubed and in adjustment.
The mechanicals fine tuned, I then fine tuned my shifting style with a light preload of the shifter, and a good solid boot into the next gear.
Works every time!
(except when I been riding all day and near home, and I get a bit lazy on the shift)
Oh and I stopped using Vic oil and changed to an Aussie full synthetic, ...it was revised shifting technique that actually cured the problem though.
Try it....it works.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 12 (permalink) Old 10-18-2015, 09:09 PM
Is your clutch cable adjusted properly?
Are you preloading the shifter?
Do you shift at 3,000 RPMs or higher, no lower?
Have you tried other oils? My fave (and many others here) is Rotella T-6.
PhilC64, vindex1963 and Pjv1k like this.
post #5 of 12 (permalink) Old 10-23-2015, 05:32 PM Thread Starter
Rotella T-6 oil. Use the same viscosity as the victory oil?
Terry is offline
post #6 of 12 (permalink) Old 10-23-2015, 10:00 PM
No, Rotella T-6 is 5W-40, while Vic oil is 20-40. I like the 5W part for easier cold engine start-ups.
post #7 of 12 (permalink) Old 10-24-2015, 04:36 AM
LILMAGS500's Avatar
T6 here too .
Pjv1k likes this.
LILMAGS500 is offline
post #8 of 12 (permalink) Old 10-24-2015, 08:15 AM
BP6666VR's Avatar
Completely agree with ajustment and shifting
What oil are you using? Maybe just change it for Vic oil or second choice T6 ???
I have found through oil analysis that vic oil does not last as per manual stated Miles / Km in hot climate ... I do not know for cold climate ..
I did oil analysis at intervals of 3000 Km and did not reach the recommended 8000 Km so i changed it 6500 Km, oil analysis is cheap and easy to do.
Just something to think about ?
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 12 (permalink) Old 10-24-2015, 11:09 AM
you read your owners book and it will tell you clutch spec. You can only adjust your clutch when its over night cold.
NEVER when its warm or hot.
Now you half to have a firm foot when you put it in gear. Go all the way up or down don't be lazy about it
post #10 of 12 (permalink) Old 10-24-2015, 12:48 PM
LILMAGS500's Avatar
Yes , it is .......
Weeds, Motorbikerx and BP6666VR like this.
