Clutch Cable Lube - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 16 (permalink) Old 10-25-2015, 01:56 PM Thread Starter
Send a message via Skype™ to nealflora
Default Clutch Cable Lube
What's the best lube to use on our 2012 XR and Vegas Clutch Cables. Do you lube just the pivot points or to you lube the entire cable?
Thanks
Neal, Marco Island Florida-2012 Vegas, 2012 Cross Roads
nealflora is offline
post #2 of 16 (permalink) Old 10-25-2015, 02:01 PM
Just the pivots, the cable is sheathed in a nylon type coating and grease will cause it to deteriorate. Be certain to clean the pivots and sockets before re-lubing.
post #3 of 16 (permalink) Old 10-25-2015, 02:11 PM Thread Starter
Thanks a bunch. Any waterproof Grease good?
post #4 of 16 (permalink) Old 10-25-2015, 02:21 PM
I use white lithium grease. BTW, the best and easiest way to release the cable is to rotate the pivot on top of the primary case. Do it with a channel lock type pliers.
post #5 of 16 (permalink) Old 10-25-2015, 02:35 PM
Weeds's Avatar
Iv been using synthetic marine grease ...
dentdave likes this.
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #6 of 16 (permalink) Old 10-25-2015, 05:58 PM
Jamming's Avatar
That's what I'm using as well. A tube of it was 5 bucks at Tractor Supply. I suspect it'll be a damn near lifetime supply
I use an acid brush to apply and keep it in a ziplock baggie rubber banded to the tube.
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #7 of 16 (permalink) Old 10-25-2015, 08:17 PM
Motorbikerx's Avatar
I use Moly camshaft assembly lube.
Vital to thoroughly clean the old crap off first of course.
Then as its been sitting overnight cold I check the adjustment and make sure its spot on.
I do mine twice as often as the suggests 5000 mile oil change interval, cos its so simple to do and I got extra peace of mind that my cables gonna last.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 16 (permalink) Old 10-26-2015, 03:21 AM
BP6666VR's Avatar
Moly or if it is in view i also use vasaline
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 16 (permalink) Old 10-26-2015, 11:31 AM
It's not nice having IT in view. You can get into trouble doing that, you know.
broggyr and BP6666VR like this.
post #10 of 16 (permalink) Old 10-26-2015, 11:55 AM
ByteN2it's Avatar
I'm always looking for the best fluids & lubricants available-I prefer the TFE wax base dry lubes-they won't turn into a gritty dirt attracting grease ball & they're much easier & neater to apply. I'm trying out a new lube that I can't recommend yet but looks promising-it's a ceramic wax lube that has boron nitride "nano" particles instead of the TFE/Teflon particles, I've only tested it on two of my 1911's and some fishing reels with good results.
ByteN2it is offline
