Front Brake Rotor Options? - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 29 (permalink) Old 10-26-2015, 05:21 PM Thread Starter
TechnoGeek's Avatar
Default Front Brake Rotor Options?
I might need new from Brake Rotors PN# 1911624-266
For a 2012 XR, Looked and GADZUKES!! Polaris is Real Proud of those guys!!
I'm not after bling or expect stock certificate with them, just Brake rotors. The price is pretty high in my opinion.
So what options do I have for a replacement?
I reject your reality, and submit my own!
2012 Cross Roads, Utopia Drivers Backrest, Victory Passenger Backrest, Tall Windshield, Lowers, Mirror Extenders, 3m Clear Paint Protective film.
TechnoGeek is offline
post #2 of 29 (permalink) Old 10-26-2015, 05:36 PM
Why would you need replacements? What happened to the originals?
post #3 of 29 (permalink) Old 10-26-2015, 06:08 PM
I think most brake rotors for motorcycles are expensive
vcc14 is offline
post #4 of 29 (permalink) Old 10-26-2015, 06:34 PM
DirtyDan's Avatar
Ebay is your friend
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #5 of 29 (permalink) Old 10-26-2015, 07:22 PM
Motorbikerx's Avatar
What sort of mileage has your rotors to a state of being worn to undersize? What pads are you using that wear your rotors?
Switch to Lyndalls pads theyre not
nearly as aggressive on rotors.
Oh and if your rotors measure up legally undersize then Paulie of Honda East Toledo is the best cheapest source of new originals.
Motorbikerx is offline
post #6 of 29 (permalink) Old 10-27-2015, 04:14 AM
benm's Avatar
Sort of on topic but on the last vic ride I went on ,one guy had oversized rotors and caliper reposition brackets.(cross country)
Has anyone seen a single over size rotor kit for the Vegas?
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #7 of 29 (permalink) Old 10-27-2015, 06:54 AM
Did you ask the guy riding the bike about his oversize rotor?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 29 (permalink) Old 10-27-2015, 08:28 AM
Are you talking about these oversized rotors? I wonder if the mounting points are the same as other models?
vcc14 is offline
post #9 of 29 (permalink) Old 10-27-2015, 09:44 AM
I have the Arlen Ness rotors as shown in the above picture.
They work great and do reduce the effort required for a given braking response.
There is a supplied bracket that moves the stock caliper to the necessary position for the larger rotor. Very simple 1 hour job to install, does require removal of the front wheel. Does not require any re bleeding of the brakes.
I suppose it would be prudent to put on new pads if the pads you have now had a significant amount of miles on them. I put the new rotors on when the bike was almost brand new.
But make no question, I solely put the larger rotors on for looks only.
To me, they look great and that is all I wanted. The stock system works just fine, again, just for looks.
Got them from Witch Doctors, about 5 bills or something?
Everybody has their preferences on what looks good, for me it works.
Draper is offline
post #10 of 29 (permalink) Old 10-27-2015, 10:57 AM
What happened to the OP?
