2013 XCT rear pads replacements - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 18 (permalink) Old 11-03-2015, 02:49 PM Thread Starter
gmaxx's Avatar
Default 2013 XCT rear pads replacements
Questions!
I need to replace my rear pads on my 2013 XCT. This would be my first brake replacement job. I've watched the Witch Dr. video on how to do it. Looks pretty straight forward and about a 20 minute or so job. Any tips or gotcha's I should be aware of? And of course my local dealer would be out of stock of pads. So I'll have to order them. At 45k miles I rather be doing things like this myself. When the dealership replaced the brake pads last time they went with EBC HH brakes about 40 bucks a pop. I found these on EBay Has any had experience with these pads?
Volar Motorsport Sintered HH Brake Pads
2013-2015 Victory Cross Country Tour Sintered HH Rear Brake Pads
Or would it be better to stay with the EBC brand?
EBC Hi Performance Rear Brake Pads FA196HH | eBay
Thank for your feed back guys. would like to order pads this evening.
Gmaxx
2013 XCT
Lloydz Air Filter
Ness Big Honkers Pipes
gmaxx is offline
post #2 of 18 (permalink) Old 11-03-2015, 03:40 PM
Replacing rear pads on an XCT is cake - 20 minutes including getting out your tools and putting them away I haven't replaced them yet (25m miles) but have removed them to make rear wheel reinstallation easier.
The only thing I had happen once was the pad spring popped out and it took me a bit to figure out how it went back. If you are careful, you won't have this problem. If you do, it's simple to take care of.
broggyr is online now
post #3 of 18 (permalink) Old 11-03-2015, 04:49 PM
amazon might be cheaper
post #4 of 18 (permalink) Old 11-03-2015, 05:44 PM
doobliss's Avatar
25 million miles????
Good gravy you ride alot!
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #5 of 18 (permalink) Old 11-03-2015, 07:56 PM
vindex1963's Avatar
read customer feedback carefully on ebay lots of counterfeit things end up on there that's why the prices are so good in some cases.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #6 of 18 (permalink) Old 11-03-2015, 11:55 PM
dtmmil's Avatar
i bought all three sets if my ebc hh pads on ebay, $90 shipped for all three, took less then 30 minutes to install all three sets too.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #7 of 18 (permalink) Old 11-04-2015, 12:07 AM
Motorbikerx's Avatar
I went to Lyndalls pads dearer but good!
Make sure you thoroughly clean your pistons before pushing them back in and its a good idea to bleed all your old fluid out so youve got nice clean fresh brake fluid.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 18 (permalink) Old 11-04-2015, 12:28 AM
I recently replaced the front and rear brake pads on my 13 XC and it went very well. I have no mechanical ability and was able to do it with very little issues. The only one was the front and getting the spring back but I got it after about 10 minutes and watching the Witchdoctors video a couple times. So it goes to show how easy these bikes are to work on it I can do it.
2013 Cross Country Anti-Freeze Green
Lloydz Timing wheel set at 4 degrees
Lloydz High Flow air filter
Llodz Peformance Cams HOH-VM1-DR
Lloydz Dyno Tuned
Atom Bomb exhaust
113/119
gpd445 is offline
post #9 of 18 (permalink) Old 11-04-2015, 04:11 AM
I went with the EBC HH pads front and rear, which I purchased from BikeBandit.com. I have no problems or complains with these pads and they do provide a little better braking feel and power over the stock pads.
post #10 of 18 (permalink) Old 11-04-2015, 08:04 AM
That should have been 25K.
However, 25M would still mean 25,000 and 25MM would be 25,000,000
BP6666VR likes this.
