Reverse gear problem - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 2 Post By MTVic
  • 2 Post By Honda East Toledo
post #1 of 5 (permalink) Old 12-01-2015, 03:29 AM Thread Starter
geekydad's Avatar
Default Reverse gear problem
Not sure how many folks have the reverse gear in their XCT, but I opted for it, mostly to avoid hernias trying to back up on a hill.
Had it put in when I got the bike two years ago, and it's worked very well. Recently, I've had two times that I used it and things got difficult.
In neutral, switched the gear on, then used it to back the bike up. Stopped, flip the gear off, but the electronics think the bike is still in reverse. Pretty much nothing I can do. If I put it in gear, the engine dies (by design) because it thinks the gear is still engaged.
Turn key off, back on, "R" still flashing.
Takes about 15 minutes of turning off and on, popping gears in and out, wrestling the bike around while in gear before the electronics FINALLY realize the reverse gear isn't engaged, and I can move on.
Anyone else have similar experiences?
Thanks!
2013 XCT Sunset Red, Tri-oval Stage 1 Exhaust, Lloydz ATS (+4), Lloyds High-flow Air Filter, Lloydz VFC III, Kicker Speakers, Electric Reverse Kit, Ultimate Seat w/Backrest, Passenger Armrest, Madstad Road Glide, Ness Beveled Gas Cap/Derby/Cam, FOBO TPMS,Centramatics Martinez, GA
geekydad is offline
post #2 of 5 (permalink) Old 12-01-2015, 06:26 AM
BP6666VR's Avatar
Can't help you / hope you can fix it / subscribed / and just for info (maybe you know already) this is how the vic reverse ring looks like ...uploadfromtaptalk1448985269046.jpg
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 5 (permalink) Old 12-01-2015, 07:01 AM
MTVic's Avatar
Once mine did a similar thing. They had to tow it in, and fixed it for free, luckily! It happened soon after install.
What we both learned:
1: make sure the engagement rod is properly aligned
2: don't forget to lube per the Vic service manual
3: NEVER force it into gear. If it doesn't go easily "rock" the bike forward and back slightly and it will drop in. (Feels kind of like the gears aren't exactly aligned.)
4: Never take it out of gear unless fully stopped.
And yes LOVE the reverse.
Chattanooga Mark and dentdave like this.
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #4 of 5 (permalink) Old 12-01-2015, 12:01 PM
Honda East Toledo's Avatar
I think we have sold about five of those kits, never had any issues with them, but I do remember that they do need a little more maintenance to keep them going, I can run and check and see what the service manual says.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #5 of 5 (permalink) Old 12-02-2015, 09:58 AM
rewindguy's Avatar
Yes, need insight! I am getting the kit and installing hopefully over Christmas. Any tricks of the trade so to speak would be good! Thanks!
2014 Cross Country Tour
Goldrush / Black
rewindguy is offline
