Tire Repair Kits - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 01-20-2013, 06:08 PM Thread Starter
Default Tire Repair Kits
Thinking about getting a bike master repair kit to throw in the bag ($32 on Amazon). Didn't see much in the search engine on the subject. Any opinions out there on tire repair kits to carry? Thanks in advance.
Glenn
Tucson, Arizona
1969 ish Kawasaki 500
1972 Suzuki 750 water cooled
1973 Norton 850 Commando
1976 ish Yamaha 750 Virago
1999 Harley Davidson 883 Sportster
1995 Harley Davidson Super Glide
2007 Honda ST 1300
(all of the above sold, unfortunately)
2013 Victory XC Blacked Out Red
...and a couple old airplanes in there too.
Owner, www.RVairspace.com
retpd2001 is offline
post #2 of 14 (permalink) Old 01-20-2013, 06:13 PM
arkiebiker's Avatar
I have this one...I have used this one...and it's the only one I'll carry. It works VERY WELL!!!
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
post #3 of 14 (permalink) Old 01-20-2013, 08:22 PM
toejam's Avatar
I got the Stop & Go International Tubeless Puncture Pilot Kit 6000 - no need to replace CO2 cartridges.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #4 of 14 (permalink) Old 01-20-2013, 11:44 PM
Dynaplug is the one for me! Its very compact, so simple to use, everything fits in the handle and you will lose precious little air. For better piece of mind, install Ride-On sealer and balancer. Watch the video at Ride-On.com.
post #5 of 14 (permalink) Old 01-21-2013, 06:55 AM
I don't use a ride on sealant because of what I remember from car sealants. Don't they coat the entire inside causing frustration at the tire change and leave behind a residue in the wheel?
Ride safe.
2011 CrossRoads
D&D pipes, PCV, Llyodz performance filter w/strip in place, Llyod's timing wheel (set +4) and various other visual do dads. :cool:
vagabondjpm is offline
post #6 of 14 (permalink) Old 01-21-2013, 07:10 AM
GatorJoe's Avatar
Stop and Go Plug Kit with a 12V Portable Compressor, made by Slime .. Slime the company, I don't add Slime to the tires .. For some reason mention Slime and they think talking about the goo you add to the tires..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #7 of 14 (permalink) Old 01-21-2013, 07:59 AM
depot picker's Avatar
A small compressor with a light and tire plug kit from Walmart.
depot picker is offline
post #8 of 14 (permalink) Old 01-21-2013, 08:20 AM
arkiebiker's Avatar
DynaPlug...I was a ride and go guy. The DynaPlug system looks very similar, but less cumbersome and much quicker.
I have actually used my Stop and Go system a few times and it worked well, but I am VERY interested in hearing from anyone that has ACTUALLY used the DynaPlug system on the road.
Thanks.
Searcy, AR
post #9 of 14 (permalink) Old 01-21-2013, 09:08 AM
wspollack's Avatar
I also carry the Stop and Go, along with a very small Harbor Freight compressor that is sometimes on sale for as little as $5. I've used that pump to top off tires many times. And I used the Stop and Go once on a car tire, just to make sure I knew how to use it. I drilled a hole in the (slightly remaining) tread in one tire a few days before I was scheduled to get a new set (and was surprised at how quickly the car sank to the ground); the repair worked fine.
The Dynaplug kit is smaller, and has gotten good reviews in some magazines, but I'm also not familiar with anyone's actually using it.
Cheers,
Bill P.
wspollack is offline
post #10 of 14 (permalink) Old 01-21-2013, 11:16 AM
Lostintexas's Avatar
Dynaplugs work. Kinda small, but 2-3 in a hole seems to be fine, easy enough and acceptable if needed.Pretty fast repair.
Stop and Go, there is one I almost forgot about. A complicated overpriced "gizmo" that has had a lot of reports of spitting out the plugs after breaking off the mushroom.
It is your money, $10 on a sticky rope kit and Slime compressor, or a lot more that will do the same, perhaps less effectively, and all either is really for is to get you to a tire change.
I don't think I would be comfortable long term with a plug in a MC tire.
Oh yea, what ever you get, use it 3-4 times on an old tire to get the feel of it. Learning curves are tough at night in remote places, even worse in poor weather.
YMMV
I ride with the Force.
Lostintexas is offline
