Cam Installation Question - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 01-28-2013, 02:59 PM Thread Starter
Rajder's Avatar
Default Cam Installation Question
I've got a question for the guys who have installed cams in their XC or XR. I'm installing my Lloydz cams utilizing the instructions written by PhilC64.
Thread here: https://www.victoryforums.com/showthread.php?t=15232
During the cam removal you are instructed to insert a very small magnet into a hole and pull a small pin out of the cam carrier in order to remove the cams. You can see this in the attached picture that I pulled from PhilC64's instructions. I understand the instructions. But where in the world do I get a magnet that small? That thing is tiny.
Does anyone have any ideas where I could get a very small, cylindrical magnet that I can use for this cam swap? Thanks guys.
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
post #2 of 9 (permalink) Old 01-28-2013, 03:04 PM
CrossRoads's Avatar
Originally Posted by Rajder View Post
...Does anyone have any ideas where I could get a very small, cylindrical magnet that I can use for this cam swap? Thanks guys.
http://www.rare-earth-magnets.com/ has it all. You can also try Amazon. Makes ure you look for rare earth magnets - they are small and feisty.
CrossRoads is offline
post #3 of 9 (permalink) Old 01-28-2013, 03:16 PM
woodrow731's Avatar
I cant remember how tight that pin is but you can take a small screwdriver or just a small allen wrench and run a magnet down it the same way a few time and it will be magnetized. That may or may not be strong enough.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
vic performance pipe
109 big bore
s&s .495 cams
variable clutch
woodrow731 is offline
post #4 of 9 (permalink) Old 01-28-2013, 09:22 PM
There are some screw drivers at different Auto stores, and Tool stores, that have manetized tips that might work.
2011 Cross Country
Lloydz HOH-VM1-DR Cams
Arlen Ness Big-Shot 2 P/N 18-627
Performance Air Filter
D&D exhaust
Gustafsson +4 Shield
I POD
Adjustable lowering Link
Kicker PS52504 Speakers
Titan Amp BT454
08 VTX1800F sold
06 1200R Sportster sold
1979 Yam 750 Special sold
simpletruth is offline
post #5 of 9 (permalink) Old 01-28-2013, 11:39 PM
woodrow731's Avatar
You get it figured out?
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
109 big bore
s&s .495 cams
variable clutch
post #6 of 9 (permalink) Old 01-29-2013, 01:18 AM
tonygiotta's Avatar
Instead of rubbing a magnet on a small allen wrench to magnetize it, I see no reason you couldn't just leave the wrench attached to the magnet while you extract the pin. That ought to be strong enough so long as you're using a decent magnet. I assumed that's what was going on when I saw that picture while reading through the directions...
How was splitting the frame?
'04 Kingpin - Blue w/ Tribal Flames (sold)
'12 Cross Country - Imperial Blue
tonygiotta is offline
post #7 of 9 (permalink) Old 01-29-2013, 10:12 AM Thread Starter
Rajder's Avatar
Thanks for the info guys. I didn't get a chance to work on it last night but I will give it a try tonight. I think RadioShack might sell small rare earth magnets that might work. If not then I will pick up a small magnetized screwdriver and hope that works for pulling the pin from the cam carrier.
You aren't really splitting the frame, you're just unbolting the frame at one spot and moving the frame a bit to give you a little extra room to pull the cams. I obviously haven't finished the cam swap yet but so far it really isn't that difficult of a job for a person who has some experience wrenching on a bike. It isn't nearly as bad as checking the valves on a V-Rod that is for sure.
I'll let you guys know how the rest of the install goes.
2011 Cross Country
Rajder is offline
post #8 of 9 (permalink) Old 01-29-2013, 10:22 AM
TonyChip78's Avatar
Will you be installing the adjustable timing pulley as well? Seems like a nice addition as long as you've got it drained and half pulled apart.
Sent from Motorcycle.com App
2012 Cross Roads
TonyChip78 is offline
post #9 of 9 (permalink) Old 01-29-2013, 10:48 AM
beast30's Avatar
Default Re: Cam Installation Question
I'm starting mine today too! I picked up some small earth magnets at harbor freight...not sure if they will be small enough i may have to take the dremel after the magnet...wish me luck ha ha
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
