Valve Covers - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 01-30-2013, 08:02 AM Thread Starter
Default Valve Covers
Just wanted to ask if it was possible to take the valve covers of on 2012 xc without taking the engine out?
Thank you
Sent from my Nexus 7 using Motorcycle.com Free App
shelbytwp123 is offline
post #2 of 4 (permalink) Old 01-30-2013, 08:23 AM
leighhannah's Avatar
Yes, you may have to loosen the backbone at the rear motor mount.
2008 Vision Street
Custom paint; tinted turn signals; Lloydz cams, timing gear, PCIII; Hot Vic 26" Windmill wheel, billet wedges, tips, pegs & covers; Focal IC-130 5.25" speakers, Arc Audio KS 125.2 BX2 AMP; Hot Tails custom seat...
2012 High Ball
Custom exhaust; high performance air filter; Hot Vic sissy bar, lowered 1.5" rear, .5" front; Witchdoctor 2" peg extensions & pegs, Hot Tails custom seat & passenger pad...
leighhannah is offline
post #3 of 4 (permalink) Old 01-30-2013, 10:25 AM
beast30's Avatar
yeah, actually just took mine off yesterday to swap out the cams. Once you get the front backbone up it definitely gives you more room. The cap head bolts take a 5mm Hex drive as you can see. I then sacraficed a 3/16 allen wrench and cut down to about 2 inches so I could use that in the tight spots to speed up the process.
You must be looking at getting them Powder coated?
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #4 of 4 (permalink) Old 01-30-2013, 12:15 PM Thread Starter
Default Re: Valve Covers
Yes sir and thx for imfo
