5 volt power in fairing - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 01-07-2016, 06:50 PM Thread Starter
djh3's Avatar
Default 5 volt power in fairing
Sorry folks. I have been looking for better than 2 weeks now for a write up somewhere that had pics showing a 5 volt connection under the fairing. i have only had the headlight out on mine and forgot to pin out the voltage to the couple connectors that are "free" Thinking I am going to build my own bluetooth xmit harness and GPS harness, and will need 5v power for the GPS when plugged in and to keep the BT xmitter charged.
Thanks
2013 XCT added Jan 2015
djh3 is offline
post #2 of 6 (permalink) Old 06-08-2016, 03:46 PM Thread Starter
djh3's Avatar
Part of this worked OK. I got a voltage reducer/charger with the correct plugs off e-bay. One has the micro usb I think they call it for phones and one is a mini 5 p I think? Anyways for a garmin GPS. The GPS side seems to charge OK. Have tried 2 phones on the micro connector and neither will charge. Both phones have sad something about incorrect charger. One phone was an LG the other a Samsung. Dang for now back to the freaking plug in charger.
So it is this charger and I bought cables that plug into it to convert to the plugs I needed. Maybe one lead is bad??
djh3 is offline
post #3 of 6 (permalink) Old 06-08-2016, 04:19 PM
Encmerk's Avatar
djh3,
The part you have a picture of has 2 standard USB female connections @1.5A each. I don't see mini USB or 5 pin anywhere. Wrong image? Or were you talking about the cable to feed the devices?
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #4 of 6 (permalink) Old 06-08-2016, 08:05 PM Thread Starter
djh3's Avatar
So this is same item listed by the fellow when I go into things I have bought. Shows as 12v to 5v 3a double USB.
djh3 is offline
post #5 of 6 (permalink) Old 06-08-2016, 10:37 PM
Yes, one of the USB lines could be bad. Swap them and see if the phone charges and the GPS does not.
TUGG is offline
post #6 of 6 (permalink) Old 06-08-2016, 11:15 PM Thread Starter
djh3's Avatar
Yea that was kind of my next plan of attack. But just aint got roundtuit. I need to look up also what kind of connector is under the same area for 12v power. I have some front aux lights connected to it (a gray one) But the wires are just sort of jammed in the pin area.
djh3 is offline
