Fuel filter pictures plus other views of the bike. - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 33 (permalink) Old 01-08-2016, 11:04 PM Thread Starter
Default Fuel filter pictures plus other views of the bike.
Changed out fuel filter at around 31000 miles. Uploaded some pictures out of the phone, what you know some pictures of my fuel filter change and also some different views of the inner workings of some of our bikes.
Very dirty air filter and only around 5000 miles.
Ok there is the fuel pump on the bottom of side of the tank(for those who do not know). Yes sir you have to take that out to get to the dirty fuel filter.
There that dirty fuel filter is and with only 31000 miles, and some never change their fuel filter. I thought it was pretty dirty myself.More pictures to follow.
PaiN likes this.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #2 of 33 (permalink) Old 01-08-2016, 11:09 PM Thread Starter
Default Fuel filter more pictures.
There you go new filter on the fuel pump. Nice and clean.
That's the hole it came out of. Nice and orange.
That is the area inside the tank the fuel filter has to fit into. If you do not set it in there correctly it will run out of fuel to soon.
LILMAGS500 likes this.
post #3 of 33 (permalink) Old 01-08-2016, 11:17 PM Thread Starter
Default MORE fuel pictures
Well I had the tank off for the fuel filter, decided I better clean the air filter. This is a shot looking down into the area for the air filter.
The throttle body. Poked the phone/camera down in the frame and snapped it.
Throttle body, smoooth.
Figured I would put this heat barrier on the bottom of the tank while I had it off. Gets hot here in Hades, Arizona.
post #4 of 33 (permalink) Old 01-08-2016, 11:26 PM Thread Starter
Figured it might help keep the fuel a little cooler and maybe me also,ha, ha.
Playing around. Raised the fuel tank up a bit, would let heat out easier I believe. If you look close you will see a larger gap between the engine and the bottom of the tank. What do you think? I like the looks, have not done it yet. If I do it will have to make up brackets to hold the tank up. ....I know another crazy idea.
post #5 of 33 (permalink) Old 01-09-2016, 02:40 AM
Nice pictures, thanks. There are tabs in the picture of where the fuel filter is located. Looks like round tube stubs?
Do they hold the filter or locate it?
I thought of raising the tank to see if it improved air flow to the air filter It's pretty tight in there. If you do raise it and your afr's change at WOT upper rpm let us know.
I wonder if that heat block could be applied to the frame/ air box on the outside without being and eye sore when the bike is over on the side stand. Don't know if it actually have any noticeable effect on the intake air temp at anything above idle? If it did you could find some horsepower in it. A few degrees of air intake temp change makes a noticeable difference in power.
They use something similar in some race motors on the bottoms of the manifold plenums. They say it works and they are water cooled motors which often have better heat regulation than air cooled motors.
No idea if it would really make a noticeable difference on a Vic and no dyno to find out.
Where is the fuel level sender?
Where did you buy it. That's a nice find.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #6 of 33 (permalink) Old 01-09-2016, 02:40 AM
Talk to Diamond Jim. Has made tank lift pieces just for this. Helps for air flow too. I bought a couple from him but have not had my tank off to install them yet.
https://www.victoryforums.com/1760994-post2939.html
post #7 of 33 (permalink) Old 01-09-2016, 02:45 AM
They use something similar in some race motors on the bottoms of the manifold plenums. They say it work and they are water cooled motors which often have better heat regulation than air cooled motors.
I have that heat blocker stuff under my saddlebags, under the lid of my saddlebags, under the seat, but didn't think about putting it under the tank. It would be no big deal to spray can it black. Could even use high temp paint for longevity.
I think I found the bigger sheets of the stuff at Amazon and it also comes in rolls which I found at Auto Zone if you have those where you are.
See my previous post for raising the front of the tank.
post #8 of 33 (permalink) Old 01-09-2016, 02:51 AM
Thanks
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #9 of 33 (permalink) Old 01-09-2016, 05:23 AM
TNXR's Avatar
Very nice write up and pics! I've only got 10k miles on mine after 3 years of ownership but I may change my fuel filter when I change my air filter this spring.
2011 Cross Roads Sunset Red
TNXR is offline
post #10 of 33 (permalink) Old 01-09-2016, 06:02 AM
BP6666VR's Avatar
Thanks for the cool pictures, read it twice .... Next time I make an order in the USA then I will include a fuel filter .... The fuel is maybe pretty bad here so there is a chance I will change the filter before ....
Cross Country Tour 2014 [B]
BP6666VR is offline
