Lloyds Blue Air Filter XC/XCT - Victory Forums - Victory Motorcycle Forum
 47Likes
post #1 of 85 (permalink) Old 01-27-2016, 06:15 PM Thread Starter
LILMAGS500's Avatar
Default Lloyds Blue Air Filter XC/XCT
Can someone please provide the proper cleaning / oiling of this filter media please , and thank you .
LILMAGS500 is offline
post #2 of 85 (permalink) Old 01-27-2016, 06:55 PM
Motorbikerx's Avatar
Youd be better off asking LLOYDZ direct I would think.
Cos if its not a clean and re- oil type and you oil it then itll be screwed.
If it is a clean and re-oil like the pods in my TorqueTubes I use the K&N kit for them as well as the K&N I have in my Ford.
Generally do em all at the same time.
You may get differing opinions on here, and to be certain Id be asking Lloyd.
Motorbikerx is offline
post #3 of 85 (permalink) Old 01-27-2016, 08:07 PM
depot picker's Avatar
I got the K&N kit, cleaner and oil, and used the directions that came with the kit. Works fine, lasts a long time.
depot picker is offline
post #4 of 85 (permalink) Old 01-27-2016, 08:29 PM
BP6666VR's Avatar
Lloyd's blue filter is actually RED .... And the K&N oil is RED too ..
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 85 (permalink) Old 01-27-2016, 09:00 PM
kodiakwood2's Avatar
From the literature that came with the filter
"Cleaning interval is 30,000 miles, clean with soapy water, no re-oiling is necessary"
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #6 of 85 (permalink) Old 01-27-2016, 11:59 PM
toejam's Avatar
Mine gets cleaned/oiled every other oil change with the K&N kit. Gets pretty dusty around these parts.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #7 of 85 (permalink) Old 01-28-2016, 12:01 AM
BP6666VR's Avatar
Hmmmm just read the whole Torque Tube installation instruction and cannot find anything / info regarding lubing the K&N filters .... so must go to K&N filter instructions ?
K&N Performance Air Filters, Air Intakes & Oil Filters
.. I just put K&N oil on them as mentioned by other members ... if you hold them up in the air, you can look trough them ....
BP6666VR is offline
post #8 of 85 (permalink) Old 01-28-2016, 12:12 AM
Kingsrule5's Avatar
I believe I have seen it where Lloyd himself said that is wrong and actually works against performance of the filter. But dusty is a bit more frequent like every 20k or so
Tech23 likes this.
Kingsrule5 is offline
post #9 of 85 (permalink) Old 01-28-2016, 01:00 AM
I rang K&N tech rep who said when you cant see the wire mesh as distinct from the filter medium any more its time to clean, also said anywhere up to 50,000 miles!
So I leAve mine be till around 35,000 kms which works out yearly.
I try to stay off dirt cos of belt drive.
post #10 of 85 (permalink) Old 01-28-2016, 03:51 AM Thread Starter
LILMAGS500's Avatar
Did you mention to him about the filter being blue and not red MBX ? Just curious ... Kodiakwood says no oiling for the blue filter but I know the red ones need to be oiled , I have a red one in my Bullitt Mustang .
