Satellite Antenna Location - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 02-15-2013, 06:49 PM Thread Starter
Rumrcity's Avatar
Default Satellite Antenna Location
Can anyone tell me where Victory places the satellite antenna (magnetic head) when XM is installed by Victory on the XCT? Also, has anyone found another good location for the antenna? I am currently running with it (double sided tape) on top of the reservoir on the right side of handlebar. It works, but just doesnt look good. Any input is appreciated.
Thanks,
Rumrcity
Rumrcity is offline
post #2 of 11 (permalink) Old 02-15-2013, 07:02 PM
tonygiotta's Avatar
I t mounts on top of the XM module which mounts to the back of the radio inside the fairing. There is a bunch of other extra stuff in this picture, but you can see the antenna and all the extra wire bundled on top of the module.
'04 Kingpin - Blue w/ Tribal Flames (sold)
'12 Cross Country - Imperial Blue
tonygiotta is offline
post #3 of 11 (permalink) Old 02-15-2013, 07:20 PM Thread Starter
Rumrcity's Avatar
Thanks for response Tony, Just curious if you ran the satellite radio with and without the fairing on, was there a significant difference?
Thanks,
Rumrcity
Rumrcity is offline
post #4 of 11 (permalink) Old 02-15-2013, 09:07 PM
tonygiotta's Avatar
Actually the picture is not my bike, nor do I have the XM module on my bike yet. I do however have Sirius/XM in both my Jeep Cherokee and my wife's VW Jetta.
My antenna is placed on top of the roof of my Cherokee and works quite well. I still lose signal around very tall buildings, when driving through forested areas, and anytime I go under an overpass. Overall it's a pretty reliable signal.
I installed an upgraded VW head unit in my wife's Jetta which was not originally equipped with sattelite radio, thus it has no factory roof top antenna. I mounted her antenna on a piece of steel dash support, just above the head unit. The signal must travel through her glass windshield, her plastic dash, and some A/C venting. Her signal is nearly as reliable as mine, except on overcast/cloudy days when it tends to drop out occasionally.
Moral of the story, a clear view of the sky is going to give you the best signal. That being said... if the signal can make it through the multiple layers of glass and dash in my wife's car, I'm pretty confident the plastic fairing on the XC shouldn't be that big of an issue. When the day comes that I get XM on my XC, I plan on leaving it in the factory location.
post #5 of 11 (permalink) Old 02-15-2013, 09:36 PM Thread Starter
Rumrcity's Avatar
Thanks again Tony, thats all I really needed to know!
safe riding and thanks again
Rumrcity
Rumrcity is offline
post #6 of 11 (permalink) Old 02-19-2013, 04:24 AM
vcountry12's Avatar
I left mine connected to the head unit as it comes from the factory, to this point I haven't had any issues with reception. Good Luck
2012 Cory Ness CC #176
RPW Pipes
Llyodz CAMs (Done by Rylan Voss), Air-Filter, VFC, 1/4 turn throttle ring, Adj Timing Wheel, and Reprogrammed ECM
Cee Bailey Dragon Windshield, Bag Liners and Lowers
PIAA Driving Lights
XM radio and IPOD adapter
Dragon Bobs Windshield Bag
RF amp, Polk DB651 front and Kicker Rear speakers
Mustang Vintage Seat
kewlMetal Gauge Rings
HID Headlight
Color Matched Chin Spoiler, trunk and Dash
Maxton Cheeze Wedge
RAM Mounts
HMD Pullback Bars
vcountry12 is offline
post #7 of 11 (permalink) Old 02-19-2013, 07:17 AM
Pop
I am still sorting out my antenna placement. It's cleaner to bury it in the fairing but
1. Does being hidden in a box alongside equipment that generates and receives electrical signals diminish its signal or contribute to the diminishment of signals to other equipment?
2. My understanding is that the antenna signature is what the XM satellite recognizes. That means that in order to take advantage of the XM services away from the bike the choice is to either mount the antenna in a way that allows it to travel with the Garmin or to buy an additional antenna and pay for a subscription on it.
I'm way too cheap to pay a couple hundred clams for a second antenna just so I can listen to James McMurtry and POTUS in my pup tent so I guess I will come up with a cockpit mount for the antenna.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #8 of 11 (permalink) Old 02-19-2013, 07:42 AM
Pckrfan's Avatar
I have a portable set up because I wear a modular helmet. I use a Sena SMH10 bluetooth intercom with helmet mounted speakers. The portable satellite is a Sirius Stilletto II. It is docked in a car cradle and powered by the Vic 12 volt plug. In my XR, I used the magnetic car antennae and stuck it on my rear fender just aft of the rear passenger seat. Now, I put the antennae in my saddlebag lid organizer on my XC. It works, but not as well as the rear fender IMHO. It seems to be directionally challenged, meaning if the saddlebag is opposite side of the bike to where the satellite is positioned in the sky. Don't really know if that is true, but it seems to be a reasonable conclusion based on several trips. (Same is true if the unit was not connected to the cradle and it was placed in the exterior pocket in the sleeve of my Vic jacket or if the Stiletto was in my saddlebag lid organizer and not connected to the exterior antennae.
2013 AG-XC:
Gustafsson +2 Euro Flip
JWSpeaker 8695 LED Headlight
Ma Vic (Black Tri-Ovals/S1 Package, pull backs, derby covers,
heated seat, bag bars, shorty antennae)
Ness Rad III mirrors, Avon heated grips, Wolo Bad Boy air horn
RICZ's LD PL8 bracket and lotsa blacked out stuff
GOODY'S fork mounted lowers (3M'd)
Bag graphics & inner fairing, Bad Boys Design Peoria, AZ.
Artificial intelligence is absolutely 100% NO MATCH...............for natural stupidity!
Pckrfan is offline
post #9 of 11 (permalink) Old 02-19-2013, 08:01 AM
saddlebag's Avatar
If the box is metal, then yes it will diminish signals reaching it. Being near other low powered electronics probably won't matter unless they are awfully close and operating near the same frequencies. Ignition noise is something else. That can really interfere with AM signals (or at least the AM receiver I tried on a bike once).
Seeing as the XM receiver has a lot of trouble in trees, I mount mine as high and horizontal as I can get it. Not sure it really helps all that much though.
I don't think the satellite recognizes anything. When you activate, it takes several minutes. I'm sure they are broadcasting a file, along with all the radio stations, that gets used by the XM S/N in question to "unlock itself" so to speak. But yeah, if you have one of the puck "antennas" that hook to Garmin, then your subscription is tied to the puck. The puck is actually the antenna & the receiver. Your Garmin just displays the information.
I see Pop is two steps ahead of the game...as usual.
2011 Cross Roads
saddlebag is offline
post #10 of 11 (permalink) Old 02-19-2013, 12:08 PM Thread Starter
Rumrcity's Avatar
I decided to put the antenns on top of the rt side handlebar reservour using double sided sticky tape, the antenna is black as is the reservour, you cant notice it unless you look for it and reception has been excellent. FYI POP, my XM radio was pretty inexpensive at Best Buy, I think it was $69 and came with the antenna, so I cant imagine antennas being that expensive, but I too will be lookiing for another, due to my antennas placement (especially hiding the wire) is pretty permanent.
Thanks for the reply all.
Rumrcity
2012 CCT- stage 1, Lloydz A/F, PCV, cams and dyno by Kyle, Lloydz ATS wheel,
sat radio w/ RAM mount
air horn(fairing), high beam HID,
RF amp w/polk db6501 frnt spkrs, Vic drvs backrest, 7Jurock 15" flip,
Pass handholds
Kuryakyn pegs
Cree LED lights on custom aluminum light bar.
Vic saddlebag covers, AirHawk R,
JEGS Heat Tape, AMSOIL 10W40
Rear Saber Lights
2012 Suzuki Vstrom
2006 Vulcan Nomad- sold
2003 Honda Spirit-sold
Long Island, NY
USMC 80-84
Rumrcity is offline
