Removing Gas Tank on my '13 CCT - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 02-16-2013, 10:46 AM Thread Starter
Daybreak's Avatar
Default Removing Gas Tank on my '13 CCT
My service manual is yet to show up, and I have some time this weekend so I dont want to wait. I am installing my VFCIII on the bike, which has been pre programmed by Lloyds for my D&D pipes and Lloyds AC.
I belive after searching here I got a handle on it, but never did find specifics on this exact bike, so I wanted to ask for some help before proceeding...
I drained all fuel from the tank. I pulled the side covers and removed the seat. I can now see the 2 bolts on the back of the tank to remove. Correct me if I'm wrong, but I should be removing those 2 bolts, placing a rag on the front of the tank( so not to scratch it), and tilting the tank forward to remove the fuel line and wire connector? I cant seem to see any front bolts for the tank(or maybe I didnt look hard enough)? Then the tank should lift right off?
Are the injector plugs that I need to connect the VFCIII to pretty obvious once the tank is removed?
Any helpful tips to complete this process would be greatly appreciated!
2013 Cross Country Tour
-VM1 Cams, Lloyds ATS, Lloyds AC, VFC III, D & D Pipes, VictoryHID HI/Lo kit, 1/4 turn throttle ring, Highway Pegs, 7Jurock Flip Shield....
2009 Yamaha Raider 1900 Gone...but not forgotton!
Daybreak is offline
post #2 of 10 (permalink) Old 02-16-2013, 10:50 AM
saddlebag's Avatar
You need to pull the tank backward a little bit first. The frame has a couple of rubber mounts at the front that the tanks slips onto.
2011 Cross Roads
saddlebag is offline
post #3 of 10 (permalink) Old 02-16-2013, 10:52 AM Thread Starter
Daybreak's Avatar
Ahhh! Roger! So that holds the front down. Thank you sir!
Daybreak is offline
post #4 of 10 (permalink) Old 02-16-2013, 11:12 AM
Squatch's Avatar
Be very Careful!
Fuel pump nipple is plastic.. Break it and it is a cool $200.00 to replace.
Pull the fuel line behind the cheeze wedge first and then carefully lif the rear of the tank. Disconnect the electrical connector and the tank slides back and off. There is also a Wire tie holding the fuel line on under the tank.
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #5 of 10 (permalink) Old 02-16-2013, 11:46 AM
Ninja's Avatar
You'll also need to disconnect the breather hoses near the 2 rear bolts. Here's a video by witchdoctor showing you how to install the fuel controller,
The shortest distance between 2 points is a straight line, but how much fun can that be?!
2013 XCT Sunset Red
Stage 1 Flash
CATS removed
Tri-oval exhaust
Lloydz' Air Filter
Lloydz' ATS
PCV with AT
Lloydz' Touring Cams (tuned by The Vic Shop)
Lloydz' 1/4 turn throttle ring
Madstad Road Glide shield
2013 Ducati Diavel Cromo
2006 HD VRSCR
2006 HD FXDB blacked out
Ninja is offline
post #6 of 10 (permalink) Old 02-16-2013, 12:19 PM Thread Starter
Daybreak's Avatar
Man...You guys kick a**!
Thank you very much! And that video is priceless! I searched on youtube, but somehow missed that one.
Again, thanks for the help!
Daybreak is offline
post #7 of 10 (permalink) Old 02-16-2013, 12:44 PM
wspollack's Avatar
Those rear tank bolts go through a pair of rubber washers on each side. The inner washers can only be removed after you slide the back up. As you do so, they can fall into a black hole.
The second time I needed to lift the tank up (haven't taken it completely off yet), I put painter's tape over all the openings back there.
Cheers,
Bill P.
wspollack is offline
post #8 of 10 (permalink) Old 02-16-2013, 01:03 PM
wspollack's Avatar
I just scanned in the relevant three pages from my shop manual, and put them up on my site:
http://www.billanddot.com/fuel-tank-removal-5-15.pdf
http://www.billanddot.com/fuel-tank-removal-5-16.pdf
http://www.billanddot.com/fuel-tank-removal-5-17.pdf
Cheers,
Bill P.
post #9 of 10 (permalink) Old 03-05-2013, 06:45 PM
IanXCT's Avatar
Thanks for the scans wspollack and the video Ninja. Will be putting my Lloyds filter and PCV in soon!
2013 Cross Country Tour "Bronze Mist"
D&D's, Lloyd's Air Filter, PCV, VM1 Cams, Lloyd's Timing Wheel, Crossroads HID, BaggerShield
Dyno'd by Rylan @ The Vic Shop.. 115HP 115TQ
2006 Buell XBSs
2009 Buell 1125R
IanXCT is offline
post #10 of 10 (permalink) Old 03-07-2013, 04:47 PM
MADHOG's Avatar
I haven't had to lift my tank yet, however one of my buds did on his XC. Yup, one of the rubber washers went in to a black hole. I guess when I do get ready to lift mine I'll ba taking extra caution.
2012 XCT (Black)
Tri-Oval Exhaust
USAF, MSgt (Retired)
I.Y.A.A.Y.A.S.
MADHOG is offline
