14k On Stock E-3 Rear Tire!!! - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 20 (permalink) Old 02-24-2016, 09:38 AM Thread Starter
Foto Joe's Avatar
Default 14k On Stock E-3 Rear Tire!!!
I finally bit the bullet yesterday and changed out my stock rear tire for an identical E-3 in hopes that I can get some where around the same mileage out the new one. The old one came off at 13,855 miles and could have easily gone another 500-1,000 around town but I'm getting ready to hit the road for a week or so and didn't want to have to deal with it.
I am completely dumbfounded as to the mileage on this thing, I have never owned a heavy bike that even came close and 9 or 10k is about the best that ever could be done occasionally. So what do I chalk this up to???
A few things with one of them being the weight reduction of a CC versus a heavy Electra-Glide, the less mass that has to accelerate/decelerate the less friction will be on the contact patch of the tire. The other being the power band of the Vic engine, i.e. it isn't exactly a "puller" at 1,200 rpm so unless you've got wrist control issues so to speak the acceleration from a stop is actually a lot milder than some other engines.
I think in my opinion the most critical part of the extended wear on this tire though is the introduction of balance beads. I installed Dyna Beads in the tires right after I got the bike. The wear pattern on the rear tire even at 14k miles was even, no cupping or odd dips or swirls, just a worn down tire.
When I get back from my little adventure in a couple of weeks I'm gonna have to swap the front tire out too.
@"[email protected]_ _ _
Ambition is a poor excuse for not having enough sense to be lazy.
2017 Cross Country
Stage 1 & Tri-Ovals
Foto Joe is offline
post #2 of 20 (permalink) Old 02-24-2016, 09:42 AM
LILMAGS500's Avatar
Got 18,000 out of mine and could have gone farther .... Just changed it out for an Avon Cobra .
LILMAGS500 is offline
post #3 of 20 (permalink) Old 02-24-2016, 10:06 AM
vindex1963's Avatar
E3 is a great tire I'm at 12,000+ and am about 1/2 way or so.
I had an 09 Ultra I got over 18,000 on but I tend to ride a bike like I paid a lot of money for it.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #4 of 20 (permalink) Old 02-24-2016, 10:11 AM
I barely made it to 10k with mine
vcc14 is offline
post #5 of 20 (permalink) Old 02-24-2016, 10:12 AM
I had just a few hundred miles less on the rear tire on my XR when I changed it last year before a 2500 mile trip. No balance beads for me, just kept it at 42lbs and checked it before any riding I did before leaving from home. Probably had enough rubber to have done my trip but didn't want to be worried about it.
stilcrazee is offline
post #6 of 20 (permalink) Old 02-24-2016, 10:37 AM
Rajder's Avatar
I got 20,000 miles out of the original E3. After that I tried the Avon Cobra's and only got 10,000 miles out of the Avon's and the rear tire looked worse than the E3 with double the miles on it.
I will say that the Avon's handle better than the Dunlops but I couldn't live with half the mileage. Right now I'm 5,000 miles into a set of Metzler ME888's so my opinion is up in the air on those.
But from what I can see getting 15,000 + miles out of the E3's is pretty typical. If I can't get decent mileage out of the Metzlers I'll got back to the E3's. I don't like the wet handling of the E3's but if I'm getting double the mileage from the other brands then I'm sticking with them.
Edit: I forgot to mention that I run Dyna Beads in all of my tires and I'm pretty consistent about checking my air pressure and keeping it above 40 psi.
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
post #7 of 20 (permalink) Old 02-24-2016, 10:44 AM
LILMAGS500's Avatar
Nooooooooooooooo!
post #8 of 20 (permalink) Old 02-24-2016, 12:26 PM
checking the tires and using a good gauge is the most important parts for long tire life
post #9 of 20 (permalink) Old 02-24-2016, 04:30 PM
TNXR's Avatar
I was actually shopping tire prices yesterday. I've got nearly 11k miles on my XR and my rear tire is about 2/3's gone, could probably go another 4k miles or so. My tires are 5 years old though (bike was 1.5 years old when I bought it) and to me that is too old for me to feel safe. I was looking at either another set of E3's or Metz 888 but my local independent was trying to get me to consider the Bridgstone Exedra's because I a not a high mileage rider (3 to 4k miles a year) and the softer compound may work better for me since 75% of my riding is in the twistys.
2011 Cross Roads Sunset Red
TNXR is offline
post #10 of 20 (permalink) Old 02-24-2016, 05:18 PM
BP6666VR's Avatar
Bridgstone Exedra's
Have to look that one up my friend
Cross Country Tour 2014 [B]
BP6666VR is offline
