Is it a wheel bearing issue? - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 17 (permalink) Old 02-29-2016, 09:10 PM Thread Starter
Default Is it a wheel bearing issue?
Evening gents.
I have a hardball with 12 miles on the clock and I noticed that after a long ride I hear a wearing noise coming from the front wheel.
I can also feel it in the bars as well. However it's not constant only on a specific spot on rotation. With out a lift or jack I can't raise the front end up to see if I have play in the wheel. Thoughts on this?
2013 Hardball
ukturfrocks is offline
post #2 of 17 (permalink) Old 02-29-2016, 09:13 PM Thread Starter
Correction 12k miles
2013 Hardball
post #3 of 17 (permalink) Old 02-29-2016, 09:31 PM
Marius's Avatar
Don't know about bearings, but could it be the brake pads that are either worn or sticking? You should be able to visually inspect that pretty easily.
Just a thought. I'm sure others will have some ideas too. Good luck.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #4 of 17 (permalink) Old 03-01-2016, 01:41 AM
I would lean more toward a warped brake rotor going by the description. One way to get an idea is to gently apply the brakes on the front only and see if you feel it pulsate.
One other thing comes to mind is the brake piston is not returning like it should which can cause a brake rotor to warp. Sometimes some brake dust crud build up. It's easy enough to check and clean by removing the pads (and maybe the calipers) and carefully applying so pressure to the front brake to make the piston come out just a little bit then use some brake cleaner and something like a toothbrush to clean around the pistons. You will need to use a screwdriver or something to push the piston back in so the pads can fit again. Obviously that is a good time to check out the pads really well.
It can be really difficult to see any warpage on a rotor.
post #5 of 17 (permalink) Old 03-01-2016, 01:46 AM
By the way; you can get the front end up in the air by using 2x4's. Maybe 6" or so pieces. Put the bike in gear then stack as many 2x4's as you can under the bike toward the front. Lean the bike over onto the wood then do the same thing on the other side. You may need to lean it over one more time to fit another board under there. It helps to have a second person slip the wood in. (Hmmm... that just didn't sound right at all)
This works for the back end too. Dayum. Did it again!
visionjohnny likes this.
post #6 of 17 (permalink) Old 03-01-2016, 04:35 AM
Location: Cairns area. Far North Queensland, Australia.
Tears of laughter running down this old fart's face right now BBob!
Yeah - I remember wood!!!
ozpacman is offline
post #7 of 17 (permalink) Old 03-01-2016, 12:44 PM
to bad there is not a video of using the 2x4's. We did that for years before jacks came out.
post #8 of 17 (permalink) Old 03-01-2016, 12:46 PM
I found this
post #9 of 17 (permalink) Old 03-01-2016, 01:49 PM
LILMAGS500's Avatar
I would have to say "no way in hell" is it a wheel bearing , something else is more likely the problem . Without hands on it though , who can really be sure .
LILMAGS500 is offline
post #10 of 17 (permalink) Old 03-01-2016, 04:30 PM
I know this sounds crazy, but when my belt was too tight, it made a hek of a vibration noise that I would swear was coming from the front brakes.
depot picker likes this.
2005 VTX 1300C
Dan050 is offline
