Antigravity batteries (Micro Start) - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 2 Post By RICZ
  • 1 Post By BP6666VR
post #1 of 6 (permalink) Old 03-02-2016, 03:56 PM Thread Starter
necoachbw's Avatar
Default Antigravity batteries (Micro Start)
I bought one of the micro start batteries in case I ever need to jump start my bike and I installed a new battery tender from Antigravity which is made with heavier wire to prevent it from melting, but my problem is that after installing the new tender on the battery my die hard battery tender reads out connect clamps but it is plugged into the harness which is already on the bike. Has anyone else had problems with these harnesses or have any suggestions. I did order a new battery charger just in case. Appreciate any help you can give.
Thanks and Ride Safe.
Nebraska
2014 Tequila Gold Cross Country
necoachbw is offline
post #2 of 6 (permalink) Old 03-02-2016, 06:08 PM
didn't your bike have a tender cord all ready on the battery
you should only have 2 wires per terminals.
add 1/4" lock washers to each battery bolt
post #3 of 6 (permalink) Old 03-02-2016, 07:01 PM
BP6666VR's Avatar
Sorry I am not fully understanding your post ?
Is the main problem your battery tender reads "connection good" but the tender is "not connected" ??
Sent from my A51w using Tapatalk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 6 (permalink) Old 03-02-2016, 07:04 PM
Put electricians tape over the readout panel.
roadcouch and SubDude like this.
post #5 of 6 (permalink) Old 03-02-2016, 07:41 PM Thread Starter
necoachbw's Avatar
When the charger is plugged into the tender harness the charger readout is saying connect clamps, but it is already plugged into the harness.
Nebraska
post #6 of 6 (permalink) Old 03-02-2016, 07:52 PM
BP6666VR's Avatar
Aha .. Got it ... Then as others suggested
1, clean /electrical grease / star washer / tighten the battery tender lead to battery ...
2, plug it in / see if she charges with a multi meter
3, if YES then it's all good and put tape over the fault reading .... Ha ha ha
RICZ deserves a feather for his suggestion ...
SubDude likes this.
BP6666VR is offline
