Adding Fork Oil - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 03-06-2016, 08:03 PM Thread Starter
H35
H35's Avatar
Default Adding Fork Oil
Hi,
I just had a Ness rake kit installed and a 23" wheel on my 13' CC.
What I want to know is, can I add 10mm of fork oil to the forks while they are still in the bike? I'd like to firm up the ride and stop from hitting the travel limiters.
Can I just lift the bike and remove the top caps to add the oil?
Thanks
Rob
H35 is offline
post #2 of 12 (permalink) Old 03-06-2016, 08:31 PM
BP6666VR's Avatar
Hi Rob, adding oil should ideally be done forks-up ... So you can accurately add or retract oil ...
If your fork is hitting the small spring travel limiters, why not go back to the shop that installed the rake-kit ?? This would be the logic step to take ?
Not taking apart somebody else work ?
Sent from my A51w using Tapatalk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 12 (permalink) Old 03-06-2016, 08:32 PM
Motorbikerx's Avatar
Somehow I don't think it's that easy.
Someone here may be able to offer some hope, or you could approach whoever fitted the kit and wheel as you're probably not the only person that encounters this problem.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 12 (permalink) Old 03-06-2016, 09:58 PM
call rusty jones
Bike Gallery ? Rusty Jones Customs
post #5 of 12 (permalink) Old 03-07-2016, 12:53 PM
luvmyride's Avatar
I had the same issue with my 23" rake. On BIG sharp potholes, it would bottom. I added more oil and it didn't stop it completely (it did help some). I did a full change with Amsoil Shock Therapy #10 and I haven't had it happen since.
BTW the forks were removed, springs removed, tubes compressed per the manual to be sure the final fill was accurate and even
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #6 of 12 (permalink) Old 03-07-2016, 02:50 PM Thread Starter
H35
H35's Avatar
Luvmyride - how much do you weigh?
H35 is offline
post #7 of 12 (permalink) Old 03-07-2016, 02:53 PM
This is a little off your topic: I don't like to mess with suspension so I had a shop do a fork oil change this winter and upgraded to Amsoil #15 per the shop's recommendation. The bike's front end feels more solid and its much better riding than before the change.
post #8 of 12 (permalink) Old 03-07-2016, 04:20 PM
Donzo's Avatar
This is a little off your topic: I don't like to mess with suspension so I had a shop do a fork oil change this winter and upgraded to Amsoil #15 per the shop's recommendation. The bike the front end feels more solid and its much better riding than before the change.
I'm thinking of doing this - I had a small leak and got the leak fixer thingy (looks like a thin plastic book marker). and fixed the leak - but some oil was lost.
I'm curious and would like a point of reference - how much were you charged for the fork oil change?
2010 Crossroads
Midnight Cherry
No Rice
No Pork
Just Beef
Enjoy the miles....we only get so many!
Donzo is offline
post #9 of 12 (permalink) Old 03-07-2016, 04:55 PM
luvmyride's Avatar
185 for me and 130 for the wife. Hasn't bottomed once
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
VicBaggers:
+6 degree trees
Bag fillers
Tarzanz +2" bars
post #10 of 12 (permalink) Old 03-07-2016, 05:11 PM
I had new tires mounted and balanced with the service but I believe it was ~$110 for the fork service.(I pulled the forks off the bike and brought them to the shop, it would have been more labor if the shop pulled and remounted the tubes.)
