Air Fuel Meter? - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 03-07-2016, 04:42 PM Thread Starter
Default Air Fuel Meter?
Hello. Can anyone recommend an air/fuel meter that records the ratio and allows for afterwards review? I have the VFC III and would like to tune it after seeing a/f ratio under idle, acceleration, cruising, etc. I see I could rent the real-time, analog SAFR gauge for $20 without recording capability.
Thoughts?
2012 CCT, White
Grimloktt is offline
post #2 of 7 (permalink) Old 03-07-2016, 05:48 PM
Marius's Avatar
Thoughts?
You can probably sell your VFC3 and get this Doebeck Gen 4+. Comes with the fuel controler, sensor and gauge.
AFR+ - Air/Fuel Ratio gauge plus EFI controller. #1 Fuel trimming and closed loop controller.
That's what I would do if I wanted to monitor and change the AFR I were running.
I still am undecided if I will get this Doebeck or go with a VFC3. If I decide on the Doebeck I will need to weld in an o2 sensor bung since my 2007 pipes dont have one.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #3 of 7 (permalink) Old 03-07-2016, 09:44 PM
vindex1963's Avatar
Question
I had an air/fuel set up on my cross country to tune the vfc it worked out every well.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #4 of 7 (permalink) Old 03-08-2016, 05:42 AM Thread Starter
Thnx guys for the reply.
Vindex; what a/f setup did you use?
2012 CCT, White
post #5 of 7 (permalink) Old 03-10-2016, 09:45 PM
vindex1963's Avatar
I used this one.
Innovate Motor Sports On-Line Store
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #6 of 7 (permalink) Old 07-15-2016, 02:06 PM
Dos_Equis's Avatar
Originally Posted by vindex1963 View Post
Hi Vindex:
Are you also using the Innovate LogWorks software?
I have a PC-V installed on the XC but this gauge for sure will be handing adjusting the PC-V parameters. The Autotune option from Dynojet is way more expensive.
Support :: Innovate Motorsports
Thank you.
2013 Cross Country (Sunset Red)
-- Rusty Jones Customs mod mufflers, Power Commander-V, Lloydz Hi-Flow Air Filter, Lloydz ATS @ 6+, Tarzanz Bagger barz.
Houston, TX
Dos_Equis is offline
post #7 of 7 (permalink) Old 07-15-2016, 03:50 PM
vindex1963's Avatar
I sold it quite some time ago after I tuned me VFCIII.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
