Antenna coax routing - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 03-15-2016, 08:05 AM Thread Starter
Default Antenna coax routing
Can anyone tell me where the antenna coax is routed from the mount in the rear of bike up into faring?
Just added a radio/display to my xc 8ball
Marc1 is offline
post #2 of 7 (permalink) Old 03-15-2016, 09:09 AM
DirtyDan's Avatar
Along the frame and under the tank on the right side. Follows the wire loom.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #3 of 7 (permalink) Old 03-15-2016, 09:24 AM Thread Starter
Thanks DirtyDan...I was messing with it last night and that seemed to be the logical rout, but was looking for some reassurance.
Marc1 is offline
post #4 of 7 (permalink) Old 03-16-2016, 12:02 PM
Dos_Equis's Avatar
How easy to remove the whole antenna and cable? I will like to install the one that is hidden inside the fairing.
2013 Cross Country (Sunset Red)
-- Rusty Jones Customs mod mufflers, Power Commander-V, Lloydz Hi-Flow Air Filter, Lloydz ATS @ 6+, Tarzanz Bagger barz.
Houston, TX
Dos_Equis is offline
post #5 of 7 (permalink) Old 03-16-2016, 01:07 PM
epson390's Avatar
To remove you need to remove the fairing outer piece, tank, seat and rear fenders.
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #6 of 7 (permalink) Old 03-16-2016, 06:39 PM Thread Starter
Hello, I agree with everything epson390 said but I didnt have to remove the fender...if you take a peek up in there.. you can see how its run.
Marc1 is offline
post #7 of 7 (permalink) Old 03-16-2016, 07:19 PM
DirtyDan's Avatar
If you want to run a hidden antenna all you need to do is pull the fairing, unplug the antenna and install your hidden one. Unscrew the mast from the rear and you're done. I personally wouldn't waste my money on any of the traditional ones. I'd buy the one off eBay for $10 or make your own. It's just an antenna plug with 3 feet of white on it. Works better than any of the 30-50 dollar hidden ones.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
