Magnum ABS Ring - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-15-2016, 07:01 PM Thread Starter
epson390's Avatar
Default Magnum ABS Ring
Will putting a stock magnum abs ring and 21 trip the sensor. My buddy put an X1 wheel and X1 ring on his XC and now the light is illuminated. Any ideas?
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #2 of 6 (permalink) Old 03-15-2016, 09:01 PM
Default Programming maybe
I bet the computer or ECU is seeing a different ratio now between the distance the rear wheel travels in rpms compared to the different larger front wheel on the bike now. I would tend to believe it sees the rear of the bike as going faster than the front now, since the front wheel now does NOT turn as many rpms in a given distance as it use to. So it is possible they may just reprogram it for a 21" front wheel or it may be even the possibility of having to change out the ring to a different size. A good dealer ought to be able to tell you or a service rep. I would be willing to bet you have to put the program in for the Magnum is my guess.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #3 of 6 (permalink) Old 03-15-2016, 10:18 PM
NOEMTZ's Avatar
Magnum and XC ring are the same. The difference is the module on magnum is different. You need aftermarket 21" ring to fool module.
www.noemtz.com
NOEMTZ is offline
post #4 of 6 (permalink) Old 03-15-2016, 10:22 PM
where can one get one of these aftermarket rings ? thx
2014 victory XC, white.
rcmike is offline
post #5 of 6 (permalink) Old 03-16-2016, 01:59 AM
Cheez's Avatar
Witchdoctors, Vicbaggers, HMD
Cheez is offline
post #6 of 6 (permalink) Old 03-16-2016, 06:33 AM Thread Starter
epson390's Avatar
That's what I was thinking, just wanted to confirm.
epson390 is offline
