Side Panel Scoops - Victory Forums - Victory Motorcycle Forum
 16Likes
post #1 of 26 (permalink) Old 03-21-2016, 05:30 PM Thread Starter
AdamHosman's Avatar
Default Side Panel Scoops
Has anyone ever used theses before? I was wondering if they would help at all with the hot air issue in the summer time.
Side Panel Scoops for Victory | Frame | Covers, Trims & Accents | Küryakyn
AdamHosman is offline
post #2 of 26 (permalink) Old 03-21-2016, 06:05 PM
Dagwood's Avatar
Not tried those but a set of those plug covers just arrived in the post...
2014 Cross Roads Classic
Lloydz Hi-Flow air filter, Lloydz PTS +4, What O2 Sensors, Victory LED and LED Driving lights, FOBO tpms, Avon heated grips
Halifax, Nova Scotia
Dagwood is offline
post #3 of 26 (permalink) Old 03-21-2016, 06:14 PM
It hard too tell what angle those panels are on but from Kury's description they seem to be more for show then go.
post #4 of 26 (permalink) Old 03-21-2016, 06:23 PM
any thing would help I think.
As for how much only riding with them would tell
wspollack likes this.
post #5 of 26 (permalink) Old 03-21-2016, 06:33 PM
Contact Bbob if you want a real heat deflector
AZ.Leather
http://azleather.webs.com/apps/photo...bumid=13731448
post #6 of 26 (permalink) Old 03-21-2016, 07:53 PM Thread Starter
AdamHosman's Avatar
Thanks PaiN, will do!
post #7 of 26 (permalink) Old 03-21-2016, 08:09 PM
Motorbikerx's Avatar
we are sitting on top of an internal combustion engine and complaining about heat.........
RICZ, visionjohnny, TNXR and 1 others like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 26 (permalink) Old 03-21-2016, 08:24 PM
wspollack's Avatar
I didn't know about this product from Kury. Is it new? Some thoughts:
- I agree with VJ, in that maybe they couldn't hurt, in terms of keeping a little heat at bay, away from the thighs and legs.
- I wonder if they can catch some wind going toward the center, and then make it easier for your side panels to push outward, and sail down the highway ... unless your barbs and grommets are in top-notch condition (or you've added heat-shrink to a barb or two).
- I also wonder if it's possible to block too much air. That's something I've wondered before, in regard to some of those side-closeouts that are available. I mean, that rear cylinder has to get some airflow around it -- doesn't it? -- even though the 106 is also oil-cooled. That rear jug is the one that H-D shuts down on some models, in low-speed "parade mode," right?
- As Motorbikerx points out, yeah, there's explosions going on down there, so whaddya expect. OTOH, much as I enjoy my XCT, I think my next bike is going to be water-cooled.
Cheers,
Bill P.
wspollack is offline
post #9 of 26 (permalink) Old 03-22-2016, 05:05 AM
LILMAGS500's Avatar
My first thought also ....
LILMAGS500 is offline
post #10 of 26 (permalink) Old 03-22-2016, 07:42 AM
bnhender's Avatar
And riding a motorcycle and complaining about the wind....
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
