Does tire replacement equal belt adjustment? - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 26 (permalink) Old 03-25-2016, 07:29 AM Thread Starter
Default Does tire replacement equal belt adjustment?
When the CCT has its tires changed, does the dealership have to adjust the belt?
Sent from my SM-N900V using Tapatalk
2012 CCT, White
Grimloktt is offline
post #2 of 26 (permalink) Old 03-25-2016, 09:19 AM
Motorbikerx's Avatar
Definitly not....as long as they know what they're doing the belt adjustment stays untouched.
Quiz em on it before you let em touch your bike.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 26 (permalink) Old 03-25-2016, 09:41 AM
Blowndodge's Avatar
When the tire gets changed doesn't the belt have to come off anyway? If so then it needs to be readjusted.
2013 Victory XCT. Lakewood, CA
Russell Day Long Saddle.
7Jurock 14" tinted flip shield
Unplugged O2 sensors.
Stage one filter.
14" replacement ant.
Drag Specialties highway pegs.
Custom Pin-striping.
Blowndodge is offline
post #4 of 26 (permalink) Old 03-25-2016, 09:55 AM
DirtyDan's Avatar
Yep and tension needs to be released to pull the wheel
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #5 of 26 (permalink) Old 03-25-2016, 10:58 AM
ByteN2it's Avatar
I'm not a 100% sure on a CCT but I know on my Vision there's no need to touch the adjusters when pulling the rear wheel-as long as it was adjusted correctly to begin with you should be good.
I took a look at CCT service manual and in the tire removal section it says: NOTE: Axle adjuster nuts do not have to be loosened or removed, however, belt tension & alignment must be inspected after assembly.
wspollack likes this.
ByteN2it is offline
post #6 of 26 (permalink) Old 03-25-2016, 11:12 AM
As above spider, you can drop the belt just leave the adjusters be.
That way adjustment stays same when it all goes back together.
LILMAGS500 likes this.
post #7 of 26 (permalink) Old 03-25-2016, 12:07 PM
Borrec's Avatar
The manual says that is when you check belt tension with tire replacement so it may or may not. On my 4th rear tire and I haven't needed to readjust after the first one was replaced. I remove the 2 bolts for the rear shock/bar and drop the rear that way. You don't have to remove the mufflers and the adjusters stay the way they were.
2014 XCT
Atom Bomb Mufflers
PC-V
Lloydz Air Filter
Lloydz ATS
Going to war without France is like going hunting without an accordion. You leave alot of noisy useless baggage behind.
I'd rather go down the river with seven studs than with a hundred ****heads" Colonel Charlie Beckwith.
Borrec is offline
post #8 of 26 (permalink) Old 03-25-2016, 12:25 PM
so every one gave you the correct answer. Now you have to talk to dealer and the service manager will give you a answer BUT its up to tech he's the one you should talk to
post #9 of 26 (permalink) Old 03-25-2016, 05:49 PM
I disagree, its your bike, its up to you if you wanna let incompetents work on your bike.
I can check my adjustment any time I like by poking it with my finger.
Done 60,000 miles and 9 tyre changes without a drama,
According to the 'manual' I should be on my third belt by now and I'm still on the original thats had a hole in it for half that mileage.
Its your choice who works on yr bike.
Choose wisely.
Iceball likes this.
post #10 of 26 (permalink) Old 03-25-2016, 06:14 PM
navycraig's Avatar
I've replaced my tires twice and never touched the adjusters. Just because you can does not mean you need to.
Motorbikerx likes this.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
