Adding rear speakers 2013 Cross Country - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 03-28-2016, 09:06 AM Thread Starter
Good-One67's Avatar
Default Adding rear speakers 2013 Cross Country
In process of adding speakers to bags. I need info for factory plug for rears, like where you would plug in a trunk if your were to add one. First which side or where is it located, and second does anyone have schematic or description as to keep polarity of speakers correct. Thanks for your time.
2013 Cross Country, RJC exhaust, Lloyd's Filter, Timing wheel, PCV, Adjustable Rear lowering link, Goody's front lowers. NW New Mexico
Good-One67 is offline
post #2 of 2 (permalink) Old 03-28-2016, 09:24 AM
Defuse's Avatar
The trunk plug is located on the left side of the bike if you were sitting on the bike. It is between the triangle panel and the seat if I recall correctly.
2013 Zach Ness Cross Country - #110
Lloydz Air Filter // VM1-DR // PCV // ATS // D&D Unwrapped
110 HP // 110 Ft.Lbs
Defuse is offline
