Help with bahn covers please - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 14 (permalink) Old 04-01-2016, 07:17 AM Thread Starter
sep1006's Avatar
Default Help with bahn covers please
Purchased the below and tried to put them on last night. The rear one went on without any issues and seems to be stuck on pretty good. For some reason the front one will not stick, the double-sided tape doesn't seem to be as sticky on that one. Anyway I want to replace the double-sided tape. Anyone have any recommendations on where to get some that will take the heat of the engine? I went to Lowes and O'Reillys auto and neither of them had any.
Tuxedo Bahn Valve Cover Accents W/Spark Plug Fillers in Dress Up Accsy's - Engine & Components - Cross Country, Magnum, Roads - VM - Your #1 Source for US Made, Custom Victory Motorcycle Parts
2014 VIC XC PEARL WHITE
STAGE 1 UPGRADE W/K&N FILTER
BLACK TRI-OVAL EXHAUST W/CHROME TIPS
BLACKED OUT LENS'
LOWERING LINK ( DROPPED 2" )
CUSTOM PINSTRIPING
PAINTED OUTER CHIN SPOILERS
GUSTAFSON EUROFLIP +2"[/B]
RICZ LAYDOWN PLATE
DEBADGED AND REFLECTORS REMOVED
O2 SENSORS DISCONNECTED
LLOYDS TIMING WHEEL
SHORTY ANTENNA FROM MINI-COOPER
21"WHEEL KIT FROM WD
BUNCH OF NESS ADD-ONS
sep1006 is offline
post #2 of 14 (permalink) Old 04-01-2016, 07:38 AM
WeekendRider's Avatar
From what I've read here, Whichdoctors has good customer service. Those are pricey buggers so if it were me I'd contact Whichdoctors and see what they will do for you.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #3 of 14 (permalink) Old 04-01-2016, 07:54 AM Thread Starter
sep1006's Avatar
Your right, they have great customer service. But I really think I can replace the double-sided tape and fix these pretty easily. Just want to make sure I get the right tape. If I can't get this done I will then contact Jon @witchdoctors. I have recently spent almost $2000 with them and they have been great.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
post #4 of 14 (permalink) Old 04-01-2016, 08:07 AM
LILMAGS500's Avatar
3M double sided tape , and use adhesion promoter with it . Available at any parts store . It will NEVER fall off .
visionjohnny likes this.
LILMAGS500 is offline
post #5 of 14 (permalink) Old 04-01-2016, 08:08 AM
LILMAGS500's Avatar
I recommend NAPA Auto Parts
post #6 of 14 (permalink) Old 04-01-2016, 09:53 AM Thread Starter
sep1006's Avatar
Thanks MAGS, there is a NAPA near me. I will try them.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
post #7 of 14 (permalink) Old 04-01-2016, 11:31 AM
3M owens NAPA and Meguiars
any how if you're still searching for tape try a store that sells body shop supplies. Like sandpaper filler and paint
post #8 of 14 (permalink) Old 04-01-2016, 12:44 PM Thread Starter
sep1006's Avatar
Got it taken care of and thanks for the replies. Use the Gorilla Double-sided tape, good for 250 degrees so that should do it. Glad I got it on straight because I can't budge it!!!!!!!!!
LILMAGS500 likes this.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
post #9 of 14 (permalink) Old 04-01-2016, 02:12 PM
Banned
63625 is offline
post #10 of 14 (permalink) Old 04-01-2016, 04:14 PM Thread Starter
sep1006's Avatar
Originally Posted by MRMAXX View Post
Coming soon, I added a bunch of Ness stuff and the parts that were backordered will be here next Tuesday. Xmax all over again!!!
63625 likes this.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
