Lloydz air cleaner - Victory Forums - Victory Motorcycle Forum
 7Likes
  • 2 Post By PaiN
  • 5 Post By PaiN
post #1 of 9 (permalink) Old 04-02-2016, 02:12 PM Thread Starter
Default Lloydz air cleaner
Hey just checking do you have to get the whole air box or will there air filter fit right in? thanks Rick
woodchuk is offline
post #2 of 9 (permalink) Old 04-02-2016, 02:20 PM
For an XC or XR only the filter is needed. There's really no "air box" on these bikes anyway, its built into the frame.
What you really should consider if adding a Lloydz AF is a fuel controller..
RICZ and LILMAGS500 like this.
post #3 of 9 (permalink) Old 04-02-2016, 02:26 PM
PhilC64's Avatar
The fuel controller is a bit of overkill for just adding the filter. Disconnecting the O2 sensors will enrich the fuel mixture enough. He could even add the timing system without a fuel controller. Once bigger exhaust pipes are added, then he'll need a fuel controller.
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #4 of 9 (permalink) Old 04-02-2016, 02:43 PM Thread Starter
I have witch doctor pipes on it I was told by previous owner and I have added the timing wheel set to +4 .
woodchuk is offline
post #5 of 9 (permalink) Old 04-02-2016, 06:23 PM
installing lloydz air filter - Bing video
post #6 of 9 (permalink) Old 04-02-2016, 06:32 PM
Then you'll definitely want a fuel controller if you add the AF
...we are so good at spending everyone's money here
post #7 of 9 (permalink) Old 04-02-2016, 08:16 PM
Motorbikerx's Avatar
Yeah we are experts at it :-)
Motorbikerx is online now
post #8 of 9 (permalink) Old 04-03-2016, 05:04 AM Thread Starter
Ok thanks and I tried to edit info not sue how to get it to come up ?
2011 cross country
witchdoctor pipes
Lloydz timing gear
Gustafson windscreen
ISO grips
woodchuk is offline
post #9 of 9 (permalink) Old 04-03-2016, 05:06 AM Thread Starter
ok bike info did come up thanks visionjohnny
2011 cross country
witchdoctor pipes
Lloydz timing gear
ISO grips
woodchuk is offline
