CB antenna - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 18 (permalink) Old 04-09-2016, 05:45 PM Thread Starter
Richie271's Avatar
Default CB antenna
Has anyone had experience installing a ground plane CB antenna on a cross bike. Do we have enough metal on the bike for a ground plane CB antenna to work?
How low were the SWR's?
I know an NGP antenna will work but what about Ground Plane?
Thanks
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #2 of 18 (permalink) Old 04-09-2016, 10:23 PM
Maybe these photos of a CB antenna mount I fabricated will help.
post #3 of 18 (permalink) Old 04-10-2016, 11:46 AM
New Member
That looks good. But what did you do with your fm antenna ? I am trying to find a CB for my '11 but no luck. I really don't want to go J&M but I may have to. I really want a Vic CB.
rich49 is offline
post #4 of 18 (permalink) Old 04-10-2016, 01:16 PM
No fm antenna, I have a Cross Roads. The J&M CB was the only way I could go.
post #5 of 18 (permalink) Old 04-10-2016, 06:05 PM Thread Starter
Richie271's Avatar
Ricz, Very interesting pictures.
What antenna are you using with that mount?
what is you SWR reading using that mount and antenna?
I wish I could afford the J & M CB.
Thanks
Richie271
Long Island, NY
post #6 of 18 (permalink) Old 04-10-2016, 06:17 PM
J&M supplies antennas that are already SWR'd and work fantastically well. I have a 2' and a 3'.
post #7 of 18 (permalink) Old 04-10-2016, 07:10 PM Thread Starter
Richie271's Avatar
From what I have learned, No CB antenna is, (already SWR'd). They all have to be adjusted on the bike using an SWR meter. That goes for both the Ground Plane and No Ground Plane antennas. The only antennas that don't need adjusting are the (rubber duck) antennas on a portable hand held CB.
This from a major CB radio company.
"The Antenna must be tuned for all applications. Factory systems, aftermarket ad on’s, replacement antennas, it makes no difference. The antenna SWR MUST be set! There is no pre-tuned antenna."
I just found this on the J&M web site.
Note: This antenna has been designed to mount to your motorcycle easily and
attractively. The antenna staff has been pre-tuned specifically for use with J&M’s
JMCB-2003 CB. No further tuning is required.
Go figure,
Every thing I have learned says that a CB antenna must be adjusted for each installation.
Richie271
Long Island, NY
post #8 of 18 (permalink) Old 04-10-2016, 07:30 PM
What can I say Richie? After years of producing their CB/Intercoms, J&M finally realized that everything is pretty much the same no matter what bike it goes on. The coax is the same length and bikes offer pretty much identical ground planes. When I first installed my unit, all J&M offered was a generic adjustable antenna and I had a terrible time tuning it - couldn't get any range. I called John and he said they just came out with pre SWR'd antennas and he sent to me a couple and they work very,very well. Now if you're installing a CB in a cage, then that's another story and you'll have to custom SWR the antenna.
post #9 of 18 (permalink) Old 04-10-2016, 07:38 PM Thread Starter
Richie271's Avatar
Ricz
Please see my updated post. I found the instructions for the J&M radio and it is as you said. No tuning necessary. Wow, that is a great feature. A real time saver.
I still would like to see what the SWR's are on the completed installation.
How come you ended up with two antennas?
Richie271
Long Island, NY
post #10 of 18 (permalink) Old 04-10-2016, 07:43 PM
John knew I had 2 generic ones, so he duplicated them. I didn't tell him when I bought them that one was for a friend. I use the 3' one when I have the Lock & Ride backrest & rack on and a rackbag. The 2' one is used when the rack is off. Both work equally well, but the 3' affords a bit more range.
