2013 XC Oil Kit - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 19 (permalink) Old 04-10-2016, 05:10 PM Thread Starter
Default 2013 XC Oil Kit
So, dumb question of the day. I got a 2013 Cross Country. The Victory Oil Kit comes with a small washer for the drain plug, and a larger one plus o-ring for the stem where the oil filter goes. My bike never had a washer or o-ring on it when I started changing it. I'ver never put it on. Some 4 changes since.
I just changed the filter, and put the washer, then o-ring on. This time. Was this just a dealer oversight, or are these for another bike?
dashbarron is offline
post #2 of 19 (permalink) Old 04-10-2016, 05:21 PM
There's 2 things one needs to do when installing the oil filter; 1. Prime the filter and 2. Smear a thin veneer of oil on the built in gasket. I have no idea what that larger one and the o-ring might be for. I'm too frugal to buy the Vic oil kit, I use another oil (un-named to avoid another damn oil thread) and a WIX oil filter I get at an auto parts store.
DirtyDan likes this.
post #3 of 19 (permalink) Old 04-10-2016, 05:33 PM
Default Wix it up!
Use the Wix oil filter also. Very good filters. Oh and yes I use ------engine oil in it.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #4 of 19 (permalink) Old 04-10-2016, 05:41 PM
sheets's Avatar
I posed the same question at my first oil change. I was instructed to use only the appropriate size washer, such as what came off with the plug. The "O" ring and other washer are for other bikes, of which I have no clue.
2014 XCT - blue/silver - 11" Madstad windscreen - hyd clutch - Black LED headlight -
Vic backrest - Vic short antenna - Clearwater fender-mount LED driving lights -
Vic Tri-Oval mufflers - Lloydz air filter - PC/V - Dyno tuned @ RPM, Yuba City, CA. -
sheets is offline
post #5 of 19 (permalink) Old 04-10-2016, 05:44 PM Thread Starter
Good deal guys. Thanks for the quick replies. I was doing all the other fun stuff, like dislocating my arms and fingers to do tire pressure, etc.
Always smeared oil around the filter for everything. Never primed it by putting oil in, though.
post #6 of 19 (permalink) Old 04-10-2016, 06:06 PM
there is NO o-ring in kit for oil filter.
dip stick yes.
No need to prim oil filter. Just start bike and let it idle till light and pressure comes up
post #7 of 19 (permalink) Old 04-10-2016, 06:14 PM
Buy a pair of 90 degree tire air valves and have them installed when you do a tire change. Point 'em to the right side.
post #8 of 19 (permalink) Old 04-10-2016, 06:25 PM
rhino 2's Avatar
Just curious.... What weight oil do you use to prime and smear on the oil filter..??...
wspollack and SubDude like this.
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #9 of 19 (permalink) Old 04-10-2016, 06:29 PM
Originally Posted by rhino 2 View Post
[/COLOR][/COLOR]
I dab my finger in (the unspecified) oil that's going into the bike.
post #10 of 19 (permalink) Old 04-10-2016, 06:50 PM
sheets's Avatar
good point to clarify . . . the washer is for the drain plug - only.
Other than the gasket that is fixed to the new filter . . . No washer or "O" ring for the filter.
sheets is offline
