Oil change: replace washer on drain plug? - Victory Forums - Victory Motorcycle Forum
 51Likes
post #1 of 71 (permalink) Old 04-11-2016, 02:19 AM Thread Starter
Rice_Eater's Avatar
Default Oil change: replace washer on drain plug?
The service manual says to "reinstall drain plug with a new seal."
Does that mean the copper washer on the drain plug should be replaced each time that plug is pulled?
My dealers tech says they have never replaced one. (Fairly new shop)
2105 Cross Country
Pingtung, Taiwan
Rice_Eater is offline
post #2 of 71 (permalink) Old 04-11-2016, 04:32 AM
Pauljp's Avatar
I talk about replacing the crush washer in my video here.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 71 (permalink) Old 04-11-2016, 05:03 AM
Yes new washer
2006 kingpin
S&S Intake
Hard Krome 3in big straights
Ness Ram bars
tfkp is offline
post #4 of 71 (permalink) Old 04-11-2016, 07:09 AM
Motorbikerx's Avatar
yeah so they say...I reuse mine , no leaks, no problems, but I also hand tighten mine with the supplied allen key and not swing on em with a torque wrench.
up to you , they're only cheap, and how many changes are you gonna average a year
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 71 (permalink) Old 04-11-2016, 07:14 AM
Weeds's Avatar
Been reusing the washer, so far no drips....
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #6 of 71 (permalink) Old 04-11-2016, 09:01 AM
rhino 2's Avatar
I reuse the washer but reverse it [Turn it over]...but if i have any doubts about it i will use a new one their cheep enough... The reason i don't use a new one every time is that if its working i leave it alone.. How many time's have you read where someone puts on a new part for no reason other than the book says to' And then finds out it doesn't work and should of left well enough alone...
Rice_Eater likes this.
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 71 (permalink) Old 04-11-2016, 01:23 PM
irv
irv's Avatar
have new ones laying around but am still using the original.
almost 20000 miles and 3000 mile changes. the one on
my vtx was original at 32000 miles. no drips ever.
mph faster].
irv is offline
post #8 of 71 (permalink) Old 04-11-2016, 01:26 PM
SilvrT's Avatar
They say to use a new one to protect their own ass when they do the work.
I'm still using the original one.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #9 of 71 (permalink) Old 04-11-2016, 03:10 PM
kevinx's Avatar
It is a CRUSH WASHER, and not a sealing washer. It is there to work similar to a lock washer. Holding tension through compression. Allowing the drain plug to be tightened to the proper torque WITHOUT STRIPPING THE CASE. Not replacing it is a very bad idea. Advising others to share in your bad idea; is just stupid.
RICZ, tfkp, BenD and 3 others like this.
kevinx is offline
post #10 of 71 (permalink) Old 04-11-2016, 03:22 PM
Honda East Toledo's Avatar
I usually have about 30-40 of them here in stock at any giving time, for all my major brands.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
