Battery drip - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By kevinx
  • 1 Post By visionjohnny
post #1 of 10 (permalink) Old 04-16-2016, 08:13 AM Thread Starter
ftwflh's Avatar
Send a message via Yahoo to ftwflh
Default Battery drip
I noticed yesterday that when I parked on clean cement that there was a couple acid drips.Rode it again then placed a paper plate under it and it dripped again.Not much just a drop or two.
Is this normal or is there a problem?
I keep the bike on a Tender and the volt meter when running never gets over 14.2 volts.
2011 Cross Country 2007 Harley Street Bob V&H Big Radius pipes Stage one breather
1972 FLH (been through 3 wives and still loves me)
1976 Jeep CJ5 my orange turd
2008 Silverado
2005 Trailblazer
2004 V92TC GONE
ftwflh is offline
post #2 of 10 (permalink) Old 04-16-2016, 09:17 AM
Dank's Avatar
With a sealed battery no way is it normal. You need to get the battery out and neutralize the battery acid if it is on any thing on your bike fast. The acid will not stop corroding metal parts until completely neutralized the foaming acid spray is the best for detection as it changes color with contact.
2014 XR 8-Ball, 1/4turn,IAV,XF,[email protected]+8,PCV,VM1-DR,vindex1963 Bassani mod exhaust 115.04hp 114.07tq
Dank is offline
post #3 of 10 (permalink) Old 04-16-2016, 10:43 AM
Baking Soda will neutralize the acid
I wonder what you have for battery
post #4 of 10 (permalink) Old 04-16-2016, 12:00 PM Thread Starter
ftwflh's Avatar
Took battery out and everything looked good not cracked.Only thing I found was cables werent real tight.Clean it all up.Going to get a new battery asap.This
one is the original 5-6 yrs old.Bike is a 2011.
2008 Silverado
2005 Trailblazer
2004 V92TC GONE
ftwflh is offline
post #5 of 10 (permalink) Old 04-16-2016, 12:49 PM
kevinx's Avatar
At a minimum you need to flush the whole battery area with water.
ftwflh likes this.
kevinx is offline
post #6 of 10 (permalink) Old 04-16-2016, 06:09 PM
like I said Backing Soda will neutralize it and then flush with water
ftwflh likes this.
post #7 of 10 (permalink) Old 04-16-2016, 08:47 PM
Something I am not seeing here. How do you know it was battery acid? Could it be a weeping of oil fm somewhere?
Jim
2012 XCT - Pearl White
jenkins is offline
post #8 of 10 (permalink) Old 04-16-2016, 09:33 PM
Place star type lock washers under the battery bolts. Those bolts have a tendency to loosen, so check them often.
post #9 of 10 (permalink) Old 04-17-2016, 07:14 AM Thread Starter
ftwflh's Avatar
Jim
Acid tastes different from oil
2008 Silverado
2005 Trailblazer
2004 V92TC GONE
ftwflh is offline
post #10 of 10 (permalink) Old 04-17-2016, 11:30 AM
if you put Baking Soda on aicd it will bubble up if you put it on oil or water it does nothing
