XM Antenna Location ? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-17-2016, 03:50 PM Thread Starter
dentdave's Avatar
Default XM Antenna Location ?
So I just installed the factory XM radio on my bike yesterday and everything went well and worked as it's supposed to .
Today while out a ride I noticed that I lose signal under trees , not a bunch of trees like riding in the mountains. Prior to this I used my Garmin 665 with XM and it worked good around town and everywhere else we ride with the exception of up in the mountains. While riding in the mountains once or twice a year was no big deal as we just switched over to the music stored on a SD card inside the garmin.
Anyhow I know the antenna needs a clear view of the sky and right now its attached to the radio mount as thats the way it comes. So for all of you that relocated the antenna where did you put it for the best results .
Also has anybody had any luck with the XM antenna made for motorcycles like this one.
One more question , what type of devise are being used for putting music on a SD card and playing it threw the AUX cable. Dont want to use my phone and this would only be for when the XM goes out.
Thanks for the help.
David
www.dentdave.com
2012 Cross Country Tour
IBA # 33520 - 1040 in 24, 04 / 2008
1036 in 24, 10 / 2014
Michelin Primacy Alpin PA3 ZP 195/55/16
dentdave is offline
post #2 of 6 (permalink) Old 04-17-2016, 10:01 PM
StL Mike's Avatar
Dent Dave, twice now on two different bikes, my water proof Garmin XM antenna got wet and quit working in the middle of nowhere. Now, using the USB extension cable that comes with Garmin XM antennas, and some heavy duty velcro, my antenna is mounted inside, to the top of my tourpack. - Mike
2012 Pearl White Cross Country Tour
D&D Wrapped Slipons, with Lloyd's High Flow Airbox
Lloyd's 116 Kit, Touring Cams and Timing Gear
Unlocked ECU
Power Commander V and AT
2" Pull Backs
Victory rider's Backrest
Victory Luggage Rack
Madstad 13" Windshield and Brackets
StL Mike is offline
post #3 of 6 (permalink) Old 04-18-2016, 10:45 AM
I have my XM antenna under the front fairing on a plate similar to an amp rack. It get's decent reception most of the time but not all of the time. I wish there was another option but I guess it is what it is. I switch over to phone or FM when I loose XM for large chunks of time.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #4 of 6 (permalink) Old 04-18-2016, 09:07 PM
StL Mike's Avatar
I started with my XM antenna mounted on top of the radio on a plate - reception was so bad is one of the reasons that I moved it into my tour pack. - Mike
Unlocked ECU
2" Pull Backs
StL Mike is offline
post #5 of 6 (permalink) Old 04-19-2016, 07:25 AM
DirtyDan's Avatar
Mine is placed on the upper black plastic piece of the fairing under the windshield cutout just off to the side. Works well and barely visible.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #6 of 6 (permalink) Old 04-19-2016, 10:48 AM
StL Mike's Avatar
After losing 2 Garmin XM antennas to rain, I'd be hesitant to put the antenna out in the open. - Mike
Unlocked ECU
2" Pull Backs
StL Mike is offline
