Squeaky Belt solution found - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 19 (permalink) Old 04-21-2016, 01:53 PM Thread Starter
ostbob's Avatar
Default Squeaky Belt solution found
If you're like me you've tried everything and it just keeps squeaking. I tried silicone lube and it would go about 350 miles before it would start up again. But I just tried this stuff I got at Home Depot and I'm over 1200 miles. This is the best lube I've found. Cover the wheels etc when you spray it on the pulley and belt because when it drys its a white color.
Thought I would pass the info along.
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #2 of 19 (permalink) Old 04-21-2016, 02:54 PM
I started getting a squeaky belt right before my first tire change in 2014. I must have adjusted it properly when remounting the wheel, because I have not gotten a single squeak out of it since then, and I changed the tire again late 2015.
The first time, I dismounted and remounted my own tires, and the bead breaker I had required me to remove my pulley. Not sure if I out it back in the same spot, but zero squeaking since, even after the 2nd change.
Something has got to be out of alignment. Perhaps take the pulley off of the wheel and rotate it one or 2 holes?
post #3 of 19 (permalink) Old 04-21-2016, 03:57 PM
Blowndodge's Avatar
Adjusting the belt so it wouldn't squeak was a pain for me as well. finally have it quiet. Secret?:
I adjust the belt to the looser side of tolerance on my CCT.
I have it adjusted almost touching the inside of the rear pulley.
Each time I tried to adjust it even 1/32 of an inch more to the middle of the pulley (still very visibly left of center) that belt would walk itself to the outside of the pulley and squeak like crazy.
Something about the warpness is some pulleys won't allow centering but only just off the inside left of the pulley where it will stay quiet.
2013 Victory XCT. Lakewood, CA
Russell Day Long Saddle.
7Jurock 14" tinted flip shield
Unplugged O2 sensors.
Stage one filter.
14" replacement ant.
Drag Specialties highway pegs.
Custom Pin-striping.
Blowndodge is online now
post #4 of 19 (permalink) Old 04-21-2016, 04:27 PM
Motorbikerx's Avatar
That's where mines sat for 60,000 miles and it's a bit on the loose side.
Not a problem at all, I never mess with it, my tyre shop knows Vic's and the fact there's no need to mess with adjustment once past initial break in adjustment.
Set and Forget.
Motorbikerx is offline
post #5 of 19 (permalink) Old 04-21-2016, 09:41 PM
djh3's Avatar
Had a Kawasaki 900 Vulcan. They were dang picky about belt adjustment. Not so much tension, but where it had to run on the rear pulley. The rear swing arm had like notches on it for alignment I suppose. But the way the belt had to run one side was to onside of a mark and the other side was slightly to the other. Maybe a 1/16th or so offset if you were looking at it. You would think it had the tire set a bit crooked, but it never wore the tire funny.
2013 XCT added Jan 2015
djh3 is offline
post #6 of 19 (permalink) Old 04-22-2016, 06:49 AM
Tarzan's Avatar
My bike had a squeak pretty much right after I bought it. I took it in a couple months ago to have it adjusted and they cleaned and sprayed dressing on it, which lasted about 1000 miles. So I took it back in a few weeks ago and they wanted to try adjusting it agaiin and charge me again. I told them no, I want it repaired. I'm not doing this every month. They were able to get it it fix under warranty. They replaced the belt and pulley.
BenD likes this.
'14 Ness XC
Tarzan is offline
post #7 of 19 (permalink) Old 04-22-2016, 10:18 AM
SilvrT's Avatar
33,000 kms and one rear tire change on mine and never a squeak and I didn't change the adjustments when I replaced the tire.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #8 of 19 (permalink) Old 04-22-2016, 11:02 AM
wspollack's Avatar
My solution: get to be an old geezer, wear hearing aids off the bike but custom-molded ear plugs while riding, and no belt squeak ... or maybe there is, but I can't hear it.
Cheers,
Bill P.
wspollack is offline
post #9 of 19 (permalink) Old 04-22-2016, 11:10 AM
SilvrT's Avatar
Please provide instructions for the Blue part ...
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #10 of 19 (permalink) Old 04-22-2016, 11:28 AM
wspollack's Avatar
Dunno. Just luck out, I guess.
Cheers,
Bill P.
