Failing Rear Lowering Links.. Is This A Thing? - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 17 (permalink) Old 05-02-2016, 10:08 AM Thread Starter
volthause's Avatar
Default Failing Rear Lowering Links.. Is This A Thing?
Sorry for the partial click-bait, but I'm curious who else has had problems with rear lowering links?
I had a squeak develop in the rear suspension, so I decided it was time to tear it all apart and figure out what needed greasing. What I found was a little more disturbing.
Mounting bolt is bent, and was beginning to be machined through. Anyone know what causes this kind of failure? Obviously the onus is on me for using a non-factory part, not trying to blame-shift here.
Link is 4 years old and has 7,000+ miles on it.
2011 Black Cross Country
2013 Ducati Hypermotard
2015 Honda CRF250L
1974 Honda CB550
volthause is offline
post #2 of 17 (permalink) Old 05-02-2016, 10:13 AM
I saw several others posting over the last year or 2 about lowering links that failed in the same way.
post #3 of 17 (permalink) Old 05-02-2016, 10:42 AM
BenD's Avatar
This is the only type of link that I have seen fail. The heim joint is not at all like the factory pivot. Maybe it's not designed for the stress loads created by the suspension.
Tech23 and LILMAGS500 like this.
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #4 of 17 (permalink) Old 05-02-2016, 10:47 AM Thread Starter
volthause's Avatar
Yeah, when I installed the link, it raised my eyebrows a bit that the heim joint on the lowering link was smaller than the stock link, which required the spacers to sit outside the joint instead of being necked-down and going inside the joint like it should be.
I'm thinking the spacers deformed, and bound the joint up, which in turn bent the bolt during a hard suspension hit.
2015 Honda CRF250L
1974 Honda CB550
post #5 of 17 (permalink) Old 05-02-2016, 06:38 PM
Yes replace this .. If you contact the manufacture he may replace it.. He offered to replace mine but I already bought a new one from witchdoctors.. If the bolt breaks like mine did the frame will set down on the back tire.. I left a 300 foot black mark.. And an equally impressive mark in my shorts. Lol
Victorypotamus
Milesx is offline
post #6 of 17 (permalink) Old 05-02-2016, 06:54 PM
LILMAGS500's Avatar
That link just looks like a piece of shit , and IS much different looking then the stock / WD link ... I would change it to a WD or Miller Link and not look back .
Tech23 likes this.
LILMAGS500 is offline
post #7 of 17 (permalink) Old 05-02-2016, 07:15 PM
Travis P's Avatar
That looks like the HMD link... I heard that there was problems but didn't believe it.
BenD likes this.
Travis P is offline
post #8 of 17 (permalink) Old 05-02-2016, 08:24 PM Thread Starter
volthause's Avatar
Thanks for the suggestion. I think I'll probably do that.
2015 Honda CRF250L
1974 Honda CB550
post #9 of 17 (permalink) Old 05-02-2016, 08:25 PM Thread Starter
volthause's Avatar
Yes, I reached out to the manu and they offered to replace at a discount. I think I'm going to replace with a different type though. I might even go back to stock.
That is a scary ride you had. I'm so glad I found the issue before the same happened to me. Thanks for your info!
2015 Honda CRF250L
1974 Honda CB550
post #10 of 17 (permalink) Old 05-02-2016, 08:32 PM
RussB's Avatar
I just put a Witchdoctor's adjustable link on my 2014 CCT a couple weeks ago. It looked just like the OEM that I removed, I do not anticipate any problems with it, but will keep an eye on it.
I would sell you the OEM take-off real cheap.
2014 CCT
SJM Stage 1 Exhaust
Lloyd'z Air Filter
Lloyd'z IAV Idle Air Valve
Lloyd'z timing wheel (at +4)
Lloyd'z 1/4 turn Throttle Ring
Adjustable Lowering Link at about 1-1/2" lower
Easy Pull Clutch Assist Black
Arlen Ness Beveled Gas Cap - Black
Chrome 1" mirror extensions
Tank Lift Kit ~ the v o g.net
83* Valve Stems 8.3mm black
Leather Heat Shield ~ www.azleather.webs.com/ordering
Custom Luggage Rack
Third party Back rest
Victory Arm rests
RussB is offline
