2010 Cross Roads check engine light won't clear - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 05-02-2016, 03:42 PM Thread Starter
Default 2010 Cross Roads check engine light won't clear
I took the bike to the dealer and had two codes p0563 and p0519 system high voltage and idle air control circuit out of range. They tried to clear the codes and it would not clear. Bike runs good, voltage at the battery when running is 14.5 volts, battery cables were a little loose, I tightened them and still had the problem. Dealer couldn't reset and said not to worry. Problem is non of the functions will display with the check engine on.
Badtnt is offline
post #2 of 12 (permalink) Old 05-02-2016, 03:57 PM
Motorbikerx's Avatar
Answered this already elsewhere.
Motorbikerx is offline
post #3 of 12 (permalink) Old 05-04-2016, 06:30 AM
djh3's Avatar
Maybe a link to where? Please.
2013 XCT added Jan 2015
djh3 is offline
post #4 of 12 (permalink) Old 05-04-2016, 10:47 AM
in the other thread you posted about your problem
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 12 (permalink) Old 05-04-2016, 10:33 PM
djh3's Avatar
Not my thread. But I did finally stumble across it though. Both codes are similar. Me thinks the place to start looking is the sensor.
djh3 is offline
post #6 of 12 (permalink) Old 05-04-2016, 11:32 PM
Yeah but there's many sensors that can throw a code and if a dealer with digital wrench can't find it you're reduced to trial and error replacing sensors.
What hope have we got when dealers with high technology equipment can't find a fault!
Turn back the clock to carbs and points!
post #7 of 12 (permalink) Old 05-05-2016, 08:14 AM
wspollack's Avatar
I don't know about carbs and points, or maybe you were (half) kidding around. I had six carbs on my Valkyrie, and doing a carb-sync was a fair amount of hassle. And what if a diaphragm decided to rip?
But more to the point here, I don't know much about this, but I'm really surprised that a digital tool can't pin-point what's causing a digital ECM to complain. Who wrote that software?
Cheers,
Bill P.
wspollack is offline
post #8 of 12 (permalink) Old 05-05-2016, 11:39 AM
Usually if you have multiple codes and things check out fine, it's a problem with the ecm
vcc14 is offline
post #9 of 12 (permalink) Old 05-05-2016, 11:44 AM
Don Chooluvit's Avatar
If the ECM uses the OBDII protocol, once you have 3 consecutive trips without the errors showing up, the CEL will clear on its own. Easy way to do this, ride to the gas station, ride to another one, then home. 3 trips, bingo-bango-bango.
2012 Cross Roads renamed "The High Road"
Barnett Scorpion Full Clutch, HE Clutch Cable
Blacked out Chrome trim pieces
Kuryakyn Tail light trim, Sabretooth Brake lights, Multi Backrest, Driving Light Switch (Garage opener)
Boss Audio MCBK400 600W stereo
Victory HardBall Mirrors and Mini-Apes, Big Mouth Exhaust Tips
Vicbaggers Ez-Clutch, Lay Down License plate bracket
Victory Beacon LED Headlight
LSL Adjustable Levers
Custom LED Driving lights
10' of LED RGB Strip Installed
Don Chooluvit is offline
post #10 of 12 (permalink) Old 05-05-2016, 11:57 AM
LILMAGS500's Avatar
More then likely , its who's holding the tool , IMO .
LILMAGS500 is offline
