Front tire change help - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By joseph
  • 1 Post By joseph
post #1 of 10 (permalink) Old 05-11-2016, 05:12 PM Thread Starter
theja1's Avatar
Default Front tire change help
Changing the front tire on my 2014 XC...need to know what the torque specs are for the axle and/ or brake calipers. Any other info would be appreciated.
Having my work do it, and they know nothing about Victory's.....
2003 Harley Davidson Sportster (RIP)
2006 Suzuki GZ250 (traded)
2012 Honda Shadow Phantom (traded)
2014 Victory Cross Country
theja1 is online now
post #2 of 10 (permalink) Old 05-11-2016, 05:27 PM
Luciferiad's Avatar
check out user @BBob. he has a link to downloadable PDFs of the service manuals.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #3 of 10 (permalink) Old 05-11-2016, 05:35 PM
front axle,52 ft,pinch bolts 18 ft, found on the net hope this helps.
post #4 of 10 (permalink) Old 05-11-2016, 07:24 PM
I do it all wrong. I just tighten it up, call it good enough.
Motorbikerx likes this.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
post #5 of 10 (permalink) Old 05-11-2016, 07:48 PM
depot picker's Avatar
Remember it's aluminum or you'll be starting a stripped threads thread.
depot picker is offline
post #6 of 10 (permalink) Old 05-11-2016, 07:50 PM Thread Starter
theja1's Avatar
This is correct
post #7 of 10 (permalink) Old 05-11-2016, 07:51 PM Thread Starter
theja1's Avatar
THere was a 2013, will work!
post #8 of 10 (permalink) Old 05-12-2016, 09:13 AM
Pauljp's Avatar
I have a video here that shows you all you need to know about installing the front wheel.
The install part starts at the 5:00 mark which I have adjusted in the link.
Hope this helps.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #9 of 10 (permalink) Old 05-12-2016, 11:47 AM
Motorbikerx's Avatar
Same here joseph, only things I use a tension wrench for are heads mains and big ends, the rest is experience.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is online now
post #10 of 10 (permalink) Old 05-12-2016, 05:10 PM
Depot, for me its not a matter of seeing how tight I can get it without stripping something. I simply snug it up, that's all that's needed.
Fact is unless you buy a new torque wrench every year its not accurate anyway. A few years ago on the Goldwing forum we had a guy who worked in a tool calibration and certification lab for the gov. He showed us calibration results and amazingly enough the cheap harbor freight torque wrench stayed in specs as long as the snap on. In the case of the snap on it was worth having it calibrated every year because of its initial cost. However it cost more to have that done than just buying a new one of the less expensive brans and replacing once a year.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
