Removing adjustable brake lever bushing - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 05-15-2016, 11:20 AM Thread Starter
Tinstar5541's Avatar
Default Removing adjustable brake lever bushing
I want to powdercoat my levers, but I'm concerned about the bushing and the adjustable dial. I'm pretty sure the bushing is plastic and I believe the dial is as well. With the Temps in the powdercoating booth, they have to come out. How can I remove this bushing with damaging it? Yes, I've searched the forums and no, I couldn't find a video on the WD site.
Tinstar5541 is offline
post #2 of 10 (permalink) Old 05-15-2016, 12:02 PM
not sure how you would but you could do this
Lever Set Black in Levers - Handlebars & Accsy's - Cross Country, Magnum, Roads - VM - Your #1 Source for US Made, Custom Victory Motorcycle Parts
post #3 of 10 (permalink) Old 05-15-2016, 12:36 PM Thread Starter
If I wanted to buy them, I'd have done so. There is no reason to buy new levers for that price when I can get them powdercoated for $25
post #4 of 10 (permalink) Old 05-15-2016, 05:29 PM
wspollack's Avatar
I'm not so sure that either the bushing or dial are plastic. Easy to find out, by taking a single bolt out, and using a magnet in the area. I believe the levers are aluminum, the dial steel, and the bushing some sort of metal.
@LILMAGS500 has a friend who does powdercoating. I'm not sure whether he's a pro or a semi-pro, but he did mine (in gloss black), and they came out perfectly, dial included.
Mags knows more about this process and his friend's work, and hopefully he'll chime in here.
Cheers,
Bill P.
wspollack is offline
post #5 of 10 (permalink) Old 05-15-2016, 05:45 PM
I hope you don't lose the spring and ball bearing
post #6 of 10 (permalink) Old 05-15-2016, 06:54 PM Thread Starter
Thanks. . I figured there is way to drift out the bushing and remove the dial assembly. I can see how the assembly is held in by the bushing. I would just rather hear from a pro as to the proper way to do it
post #7 of 10 (permalink) Old 05-15-2016, 07:37 PM
Jamming's Avatar
I was going to do the same thing, however I ran into Victory of Mesa Az store in Apache Junction and they had a set of black levers for 149.00. Screw it..I bought them and they look great!
Funny cause I'm a cheap bastid... 😀
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #8 of 10 (permalink) Old 05-15-2016, 10:01 PM Thread Starter
I decided to just wing it. I sprayed it down with WD40, took a 7mm long socket and gently tapped out the bushing. It is, in fact, metal. The dial assembly came out easily. Now, I can get the levers and the dial powdercoated for a fraction of a set of new levers. It's better having it disassembled so as to ensure the powder doesn't get where it shouldn't be.
post #9 of 10 (permalink) Old 05-16-2016, 06:53 AM
wspollack's Avatar
If it's a tight fit after powdercoating, you may have to sand down the top or bottom. I'm talking about how the lever rests in the opening, not the bushing. My powdercoated levers were okay in this respect -- they still could pivot fine -- but Mags warned me that I might have to do this.
Cheers,
Bill P.
post #10 of 10 (permalink) Old 05-16-2016, 07:15 AM Thread Starter
Will do, thanks
