iPod cable options? - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 15 (permalink) Old 05-15-2016, 04:26 PM Thread Starter
id-man's Avatar
Default iPod cable options?
There's something wrong with my saddlebag iPod cable. I get a clicking noise in the audio and it won't charge my iPod or iPhone. I suspect the cable is kinked, pinched, cut or otherwise compromised somewhere along its length, and instead of trying to track that down or replace the whole cable I'd prefer to abandon it altogether and get a short cable to come directly out of the dash. Does such a part exist? I don't think anyone would argue that the really hot setup would be if our dash had a USB input that interfaced with the stereo but till something like that becomes available I'd gladly welcome a 30-pin cable in the frontal dash area.
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
post #2 of 15 (permalink) Old 05-15-2016, 09:49 PM
djh3's Avatar
Mine is in the left front leg fairing glove box. My connector is up front bu the lower left corner of the gas tank. So I supose you could just get a Ram Mount for the ipod/phone and run your cable up the handle bars to it.
2013 XCT added Jan 2015
djh3 is offline
post #3 of 15 (permalink) Old 05-16-2016, 08:09 AM Thread Starter
id-man's Avatar
Originally Posted by djh3 View Post
Mine is in the left front leg fairing glove box. My connector is up front by the lower left corner of the gas tank. So I suppose you could just get a Ram Mount for the ipod/phone and run your cable up the handle bars to it.
Umm, did you say the 30-pin connector is in the fairing box but plugs into the main harness to the left side of the tank? You've followed it up and can see where it plugs in? That would be cool! I'll take a look and see if my 2010 has a plug in that location. Your answer leads me to believe there must be a shorter cable available which would plug right in to the factory harness. I already have a Ram mount on the handlebar for my phone, and this setup would allow me to power it, play music, and monitor maps while under way. Anyone know the part number for the shorter cable?
Cape Cod, MA
www.VicWrapz.com
id-man is offline
post #4 of 15 (permalink) Old 05-16-2016, 09:06 AM Thread Starter
id-man's Avatar
Wait I found the cable - and DUH! - it's the same piece I already have in my right saddlebag (dumbass).
$109 from Victory or I could just unplug my existing one and relocate it to the front harness connection beside the steering head. I am definitely doing that first before I buy anything new because there's still an issue I'm chasing - an annoying clicking sound that seems to be in the background of everything I play. Relocating the connector will tell me if the issue is something in the long length of cable stretching to the bag, or something closer to the radio unit up in the fairing. If the issue turns out to be in the radio well, we'll just take that one step at a time. I will report any new developments.
Cape Cod, MA
www.VicWrapz.com
id-man is offline
post #5 of 15 (permalink) Old 06-11-2016, 05:04 PM Thread Starter
id-man's Avatar
Hey if anyone's still following this thread I worked on it some more today - and got nowhere!
First of all, to clear up what djh3 said about a connector up front by the neck, no such luck on a 2010...that is either for later years or only touring models, or both.
So to see if the problem is in my extension cable I opened my fairing and plugged the ipod adapter from my saddlebag (pictured above) directly into the radio harness inside the front fairing - then plugged in my iphone and at first I thought there was NO TICKING but my excitement was short lived when I realized it still wasn't charging, and before I was done dicking around with it the ticking was back too.
Something is very glitchy about the whole deal and now I'm starting to suspect the N-Touch 30pin adapter - or the radio head unit itself. Looking for a pinout diagram to better understand what's happening with all those wires on that 30-pin adapter if anyone knows where to find one. Also wondering what's inside that black box - I figured it was just some noise suppression resistors but maybe there's circuitry that's been damaged?
I mentioned in a different thread that my adapter had been mangled by its former owner and I repaired it (Pic below). I have learned from today's trials that the 2 plugs serve 2 functions - the smaller one with 3 wires is audio only, while the other larger bundle is controls only, one of which should be the charging wire. Another curiosity is if I unplug the control cable the ticking instantly and completely stops, but the music keeps playing, I just can't change tracks.
Here is the way my plug looked before I repaired it:
Here's the repaired cable plugged directly into the radio harness inside front fairing:
Cape Cod, MA
www.VicWrapz.com
id-man is offline
post #6 of 15 (permalink) Old 06-11-2016, 05:21 PM
Victory Motorcycles Hard LOWERS iPod Kit for 2012 2016 Cross Models Hard Ball CC | eBay
iPOD Cord | Victory Motorcycles Store
post #7 of 15 (permalink) Old 06-11-2016, 07:29 PM Thread Starter
id-man's Avatar
Thanks, I am aware of those parts. One of those is likely to be my problem - if not then it must be up in the head unit itself. I was hoping for a way to troubleshoot it further before throwing money at it which might not resolve the issue. If it's in the head unit I'm not even sure I'd fix it vs going aftermarket with a head unit that had more power, deeper EQ functions, and built-in bluetooth capability.
Cape Cod, MA
www.VicWrapz.com
id-man is offline
post #8 of 15 (permalink) Old 06-11-2016, 07:51 PM
Bhunt19's Avatar
Default Hmmm...
If memory serves, there is a thread about clicking in sound from an iphone somewhere in the forum. I seem to remember someone saying that a setting change on the phone caused the clicking to stop. I'll do a lil diggin to see what i can come up with, but if anyone recalls that thread, please chime on in!
2014 XCT, Black, Stage 1 tune w/Tri Ovals, 1/4 turn, Lloyds A/F, ATS @+4
2006 VStar Custom
Bhunt19 is offline
post #9 of 15 (permalink) Old 06-11-2016, 07:59 PM
Bhunt19's Avatar
Default found it!
Ok, so i found the thread, i'm guessing you already know about Id Man!! You've already tried the Airplane mode trick and it didn't do diddly for ya. I'll go back to my perusing! Good luck finding the cause & keep us posted.
id-man likes this.
2006 VStar Custom
Bhunt19 is offline
post #10 of 15 (permalink) Old 06-11-2016, 08:21 PM Thread Starter
id-man's Avatar
I'm hoping to run into some vendors at Laconia next weekend who can show me upgrade options for the Head unit that will interface with the dashboard display and handlebar controls.
beard_life likes this.
Cape Cod, MA
www.VicWrapz.com
id-man is offline
