No Power to Headlight WTF? - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 05-30-2016, 04:40 PM Thread Starter
SilvrT's Avatar
Default No Power to Headlight WTF?
K ... I went to hook up the LED headlight and it didn't work. Hooked the stock headlight back up and it's not working either. So, either there is a fuse or something somewhere that blew. I checked the fuses in the fuse box but they are good. Just no power getting to the headlight wiring where it connects to the light.
Any Ideas??
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #2 of 10 (permalink) Old 05-30-2016, 04:47 PM
rhino 2's Avatar
Sometimes fuses look good, but there not...Put a new one in and see if it works now...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #3 of 10 (permalink) Old 05-30-2016, 05:15 PM Thread Starter
SilvrT's Avatar
been there, done that.
I'm wondering if the relay blew ?
Is there any other fuse for the headlights other than what's in the fusebox?
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #4 of 10 (permalink) Old 05-30-2016, 05:35 PM
guessing bad relay. Don't know if LED uses different relay
use meter and check power at relay
post #5 of 10 (permalink) Old 05-30-2016, 05:58 PM Thread Starter
SilvrT's Avatar
ahhh HA!!
Found the problem!
Here's the product I ordered...
Victory Motorcycles Chrome LED Headlight 2010 2016 Cross Models 07 16 Cruisers | eBay
Turns out the polarity is reversed. At least they include a female connector for each light that you can wire into your stock headlight wires.
Not only that but... what they mark as high beam is actually the low beam so, I guess China is completely reverse of us!! LOL
Anyhoo, they are now working. Can't explain the "no power" thing... went back and checked with a tester a second time and there was power ... yet at first there wasn't. Perhaps the relay resets itself?
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #6 of 10 (permalink) Old 05-30-2016, 06:28 PM
Lest us know how well they work
vcc14 is offline
post #7 of 10 (permalink) Old 05-30-2016, 08:35 PM
LILMAGS500's Avatar
That's some scary shit just to make an LED light work ... Hope it works out well for you silvr , especially long term .
LILMAGS500 is offline
post #8 of 10 (permalink) Old 05-30-2016, 08:40 PM
Simohoss's Avatar
Default Reverse polarity
I went through the same thing last week. Glad you found the problem.
Simohoss is offline
post #9 of 10 (permalink) Old 05-30-2016, 08:48 PM
Maybe when they say "high beam" they mean "high bulb", as opposed to lower bulb. Dunno, guessing.
post #10 of 10 (permalink) Old 05-30-2016, 09:15 PM Thread Starter
SilvrT's Avatar
The wires were actually marked with a tag, one with "H" ... the other had "L" on it.
My 69 year old mind ASSumed that "H" meant high and "L" meant low ... but alas, it seems "L" must mean Longer range whereas "H" must mean .... uhhhh Headlight? LMAO
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
