measurment for belt play - Victory Forums - Victory Motorcycle Forum
 13Likes
post #1 of 21 (permalink) Old 05-31-2016, 02:03 PM Thread Starter
Default measurment for belt play
Anyone have a good idea on how to measure the deflection in the belt. really cant get anything under there like a ruler. I know it is a silly question but.....
Jim
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #2 of 21 (permalink) Old 05-31-2016, 02:15 PM
WeekendRider's Avatar
I use a tape measure, one that locks the tape. I set the base of the tape measure on the ground and the tape pointing up and extended 6 or 8 inches. I have a mark on my swing arm that is about the center between the pulleys so that I consistently measure from the same place. I note where the belt is on the tape and then I use my belt tool to push on the belt until the correct pounds of pressure. The deflection is the location on the tape with the belt at rest versus where the belt is on the tape with the correct pressure from the tool. Does that make sense?
wspollack likes this.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #3 of 21 (permalink) Old 05-31-2016, 02:33 PM Thread Starter
yup makes a lot of sense
Ya know i just thought of that. I have tapes all over the place.
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #4 of 21 (permalink) Old 05-31-2016, 09:28 PM
djh3's Avatar
Boy I hate to ask, but where and what would a belt tool look like and a guy find one. I'm thinking its sort of a fish scale looking device.. There has to be a better way.
2013 XCT added Jan 2015
djh3 is offline
post #5 of 21 (permalink) Old 05-31-2016, 09:32 PM
This is the one I have:
Belt Tension Gauge
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #6 of 21 (permalink) Old 05-31-2016, 11:46 PM
adamnorthup's Avatar
Motion Pro makes a great one for ~$25
adamnorthup is offline
post #7 of 21 (permalink) Old 05-31-2016, 11:47 PM
Just like the one in the link i didnt notice before i posted
post #8 of 21 (permalink) Old 06-01-2016, 01:03 AM
post #9 of 21 (permalink) Old 06-01-2016, 03:55 AM
Motorbikerx's Avatar
I use my index finger and my better judgement.
Never fails, always handy (LOL) and costs nothing.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 21 (permalink) Old 06-01-2016, 05:30 AM
LILMAGS500's Avatar
You must rotate the wheel and find the spot the belt is the tightest and measure the deflection at that point . If you don't , your belt will be way too tight when set . I start with the valve stem at 6 oclock , then 9 , 12 , 3 and measure deflection . Then I set the wheel at the tightest point and adjust .
LILMAGS500 is offline
